I’m reading data from a single register in Rapid. I want to process the data by breaking it down into its individual bits. How can I do this? Or can I read it bit by bit directly? What I want to do is treat each bit as a channel—if I need to read a single register and create virtual channels, how should I define the formula? Thank you.
I suggest editing the Modbus template and setting the Bitmask checkbox for the element. Then generate channels by a wizard. It will create calculated channels with the required formulas.
