Viewing 15 posts - 391 through 405 (of 6,387 total)
  • in reply to: Some channels muted in Notifications #17222
    Notification Plugin creates notification based on events that require acknowledge.
    I suggest to compare corresponding events in the bottom event panel to find differences between the events that cause notifications and other events.
    in reply to: OPC DA to OPC UA Server Question Communicator #17221
    Perhaps, you need a central Rapid SCADA instance to collect data from all PCs.
    in reply to: Buid Rapid SCADA 6 on Visual Studio Code #17215
    in reply to: Failed to fetch. #17214
    To insert an image, please use a 3rd party image hosting. Maybe screenshot of the Network tab can clarify the situation.
    in reply to: Is there a better way to batch modify channel attributes? #17213
    If a table is exported to CSV, there are options to specify a channel range. If it does not work for you, provide additional information.
    in reply to: OPC DA to OPC UA Server Question Communicator #17212
    Should I only install Communicator on the OPC-DA computer?
    It’s enough to install Communicator and Agent to that computer. The Agent service is needed to upload the project and restart Communicator.
    in reply to: Failed to fetch. #17203
    Do the errors occur when a new table view is open, or when a table view is unloaded?
    Could you make screenshots of the errors in the Console and Network tabs?
    in reply to: Add Hist function in mimic-view.js #17200
    Access to historical archives is slow, so there is no plans to add those functions into the default implementation.
    You may request archives using these functions at your own risk.
    in reply to: The application is not ready…… #17199
    My knowledge of Linux, unfortunately, is not enough to answer the question of why an error occurs when the system starts:
    Unable to write data to the transport connection: Permission denied.
    Another unknown thing, why the same error does not occur for Communicator.
    What Linux version is used?
    in reply to: Add Hist function in mimic-view.js #17196
    Could you clarify the question?
    in reply to: The application is not ready…… #17195
    Error checking server connection:
    This error looks weird.
    Does Communicator have any connection issues?
    in reply to: The application is not ready…… #17194
    The Server service may start longer than the Webstation app and the Communicator service. The client applications try to connect Server while is it initializing. If they connect successfully after several attempts, it’s OK.
    in reply to: opc DA disconnection and reconnection issue #17191
    The above log file belong to the web application.
    You should find the log file of the communication line
    SCADA\ScadaComm\Log\lineXXX.log
    in reply to: DB Import string #17189
    Hi Simone,
    Please follow this manual.
    If you get any errors, post links to the screenshots of the settings and log files written by the module.
    use the ImportDB module to read commands from a SQL Server table and send them to the PLC
    Note that from SQL Server the driver can read values, not commands. Those values will be presented by Rapid SCADA as channel values. To convert values to commands that are send to a Modbus TCP device, Automatic Control Module is needed. The module sends commands according to different conditions, depending on channel values. For example, it can send a command of channel value changes.
    in reply to: Migrating V5.84 projects to V6 #17179
    In that case, you should ProjConv5to6.
    For small projects, it may be easier to create a new project manually, and copy scheme views.
