Failed to fetch.
  • #17202
    123
    In the Linux system, within the view section of the project, I created four tables. If I frequently switch between these four tables without waiting for all the data of the operated table to load, issues 1 and 2 will appear in the console. However, if I switch between the four tables and wait for all the data of the operated table to load, issues 1 and 2 will not occur. How can I resolve this problem?
    1.Error in getHistDataByView. Failed to fetch
    2.Error in getArcWriteTime. Failed to fetch
    This issue has not been observed in Windows 10 so far.
    #17203
    Do the errors occur when a new table view is open, or when a table view is unloaded?
    Could you make screenshots of the errors in the Console and Network tabs?
    #17206
    123
    This is the console that’s having issues.
    ​ Error in getLastEventsByView. Failed to fetch
    _doCallback @ main-api.js:53
    view.js?v=uy3uLs__pqwf_4PNuMHZZbZmSsKFWxFmSbjxll4AxWI:158 09:49:24 Load view 6 from /Main/TableView/6
    ​ Error in getCurDataByView. Failed to fetch
    view.js?v=uy3uLs__pqwf_4PNuMHZZbZmSsKFWxFmSbjxll4AxWI:158 09:49:29 Load view 5 from /Main/TableView/5
    view.js?v=uy3uLs__pqwf_4PNuMHZZbZmSsKFWxFmSbjxll4AxWI:158 09:49:29 Load view 4 from /Main/TableView/4
    view.js?v=uy3uLs__pqwf_4PNuMHZZbZmSsKFWxFmSbjxll4AxWI:158 09:49:30 Load view 3 from /Main/TableView/3
    VM5404 main-api.js:53 Error in getCurDataByView. Failed to fetch
    _doCallback @ VM5404 main-api.js:53
    view.js?v=uy3uLs__pqwf_4PNuMHZZbZmSsKFWxFmSbjxll4AxWI:158 09:49:31 Load view 2 from /Scheme/SchemeView/2
    VM6390 main-api.js:53 Error in getLastEventsByView. Failed to fetch
    _doCallback @ VM6390 main-api.js:53
    /home/ikke/图片/截图/截图 2025-10-24 09-49-53.png
    #17207
    123
    The comment section does not support image pasting, therefore I had to resort to copying and pasting the error text.
    #17214
    To insert an image, please use a 3rd party image hosting. Maybe screenshot of the Network tab can clarify the situation.
    #17218
    123
    Both point 1 and point 2 below are image links. If the images do not load when you visit the website, you can download them directly.
    1.https://imgur.com/a/hG50y57
    2.https://imgur.com/a/hG50y57
    • This reply was modified 11 months, 2 weeks ago by Mikhail.
    #17224
    Also please make a screenshot of the error requests in the Network tab.
    #17228
    123
    The URL in the first point below contains images of the request and response. If they cannot be viewed directly, they can be downloaded. After opening the new view and once the data loading is complete, the functionality can be properly accessed and used without any issues.
    1.https://imgur.com/a/SLsUa22
    So if this issue occurs, should we address it or simply ignore it?
    #17232
    If the issue is not visible to a user, it can be ignored.
