Is there a better way to batch modify channel attributes?
Forum Home Forums Uncategorized Issues Is there a better way to batch modify channel attributes?
  • #17205
    wanbinqs@gmail.com
    My Rapid Scada collects data in two ways, OPC DA and OPC UA. If I export the data in CSV format, some of the OPC UA channel attributes will be overwritten when I import the data. I have a lot of points in my system and need to modify the units, decimal places, input and output of these channels in batches. What I want to ask is whether there is a way to specify which channel to export when exporting the CSV file. I can’t choose it now.
    #17213
    If a table is exported to CSV, there are options to specify a channel range. If it does not work for you, provide additional information.
    #17217
    wanbinqs@gmail.com
    How to export CSV files individually for different channels?
    #17225
    In the Administrator app, select Tools – Project Tools – Export Table. Then select an output format, and channels to export.
