Forum Home › Forums › Rapid SCADA on Linux Controllers and Raspberry Pi › The application is not ready……
- This topic has 5 replies, 2 voices, and was last updated 1 year, 1 month ago by
October 20, 2025 at 7:15 am #17186
123
ParticipantI installed Rapid SCADA on Linux. Every time I restart my computer and open 127.0.0.1:10008, the following error is displayed:
Please correct the following errors: The application is not ready. Try again later.
I have to go to the /opt/scada directory and first execute scadastop.sh, then execute scadastart.sh to start it normally.
The log content in ScadaWeb and the log content in ScadaServer are as follows:
ScadaWeb.log2025-10-20 13:44:15 [RD-pc][root][ACT] Webstation 6.2.1.0 started 2025-10-20 13:44:17 [RD-pc][root][ACT] Storage FileStorage 6.2.0.0 loaded from file /opt/scada/ScadaWeb/FileStorage.dll 2025-10-20 13:44:17 [RD-pc][root][ACT] Plugin PlgChart 6.1.0.0 loaded from file /opt/scada/ScadaWeb/PlgChart.dll 2025-10-20 13:44:17 [RD-pc][root][ACT] Plugin PlgMain 6.1.0.1 loaded from file /opt/scada/ScadaWeb/PlgMain.dll 2025-10-20 13:44:17 [RD-pc][root][ACT] Plugin PlgScheme 6.1.0.0 loaded from file /opt/scada/ScadaWeb/PlgScheme.dll 2025-10-20 13:44:17 [RD-pc][root][ACT] Plugin PlgSchBasicComp 6.1.0.0 loaded from file /opt/scada/ScadaWeb/PlgSchBasicComp.dll 2025-10-20 13:44:17 [RD-pc][root][ACT] Plugin PlgStore 6.1.0.1 loaded from file /opt/scada/ScadaWeb/PlgStore.dll 2025-10-20 13:44:17 [RD-pc][root][ACT] Plugin PlgWebPage 6.1.0.0 loaded from file /opt/scada/ScadaWeb/PlgWebPage.dll 2025-10-20 13:44:17 [RD-pc][root][ERR] Plugin PlgStore: Dictionary file not found and replaced with default file: /opt/scada/ScadaWeb/lang/PlgStore.zh-Hans.xml 2025-10-20 13:44:17 [RD-pc][root][ACT] Plugin PlgScheme: Retrieve scheme components from the installed plugins 2025-10-20 13:44:17 [RD-pc][root][ACT] Plugin PlgScheme: Added components from the PlgSchBasicComp plugin 2025-10-20 13:44:18 [RD-pc][root][ACT] Receive the configuration database 2025-10-20 13:44:18 [RD-pc][root][ERR] Error checking server connection: Connection refused [::ffff:127.0.0.1]:10000 2025-10-20 13:44:19 [RD-pc][root][ERR] Error loading application part from file /opt/scada/ScadaWeb/PlgScheme.Common - 原版.dll: System.IO.FileLoadException: Assembly with same name is already loaded at System.Runtime.Loader.AssemblyLoadContext.LoadFromAssemblyPath(String assemblyPath) at System.Reflection.Assembly.LoadFrom(String assemblyFile) at Scada.Web.Program.ConfigureApplicationParts(ApplicationPartManager apm) 2025-10-20 13:44:28 [RD-pc][root][ACT] Receive the configuration database 2025-10-20 13:45:09 [RD-pc][root][ERR] Error checking server connection: Unable to write data to the transport connection: Permission denied. 2025-10-20 13:45:09 [RD-pc][root][ACT] Receive the configuration database 2025-10-20 13:45:09 [RD-pc][root][ERR] Error checking server connection: Unable to write data to the transport connection: Permission denied.
If I execute the following commands in Linux:
sudo systemctl disable scadaagent6.service
sudo systemctl disable scadaserver6.service
sudo systemctl disable scadacomm6.service
sudo systemctl disable scadaweb6.serviceThen, after booting up, if I directly execute scadastart.sh, SCADA can start normally.
Finally, I would like to ask how to solve the problem so that it can start directly upon boot?
This topic was modified 1 year, 1 month ago by
October 20, 2025 at 7:15 am #17187123
ParticipantScadaServer.log
2025-10-20 13:44:17 [RD-pc][root][ACT] Server 6.2.2.0 started 2025-10-20 13:44:17 [RD-pc][root][ACT] Storage FileStorage 6.2.0.0 loaded from file /opt/scada/ScadaServer/FileStorage.dll 2025-10-20 13:44:17 [RD-pc][root][ACT] Start logic processing 2025-10-20 13:44:18 [RD-pc][root][ACT] The configuration database has been read successfully 2025-10-20 13:44:18 [RD-pc][root][INF] Number of active channels for archiving: 697 2025-10-20 13:44:18 [RD-pc][root][INF] Number of active channels for sending commands: 697 2025-10-20 13:44:18 [RD-pc][root][ACT] Compile the source code of scripts and formulas 2025-10-20 13:44:18 [RD-pc][root][ACT] Added the following dependencies: /opt/scada/ScadaServer/ScadaCommon.dll /opt/scada/ScadaServer/ScadaServerEngine.dll /usr/share/dotnet/shared/Microsoft.NETCore.App/8.0.16/netstandard.dll /usr/share/dotnet/shared/Microsoft.NETCore.App/8.0.16/System.ComponentModel.Primitives.dll /usr/share/dotnet/shared/Microsoft.NETCore.App/8.0.16/System.Console.dll /usr/share/dotnet/shared/Microsoft.NETCore.App/8.0.16/System.Diagnostics.Process.dll /usr/share/dotnet/shared/Microsoft.NETCore.App/8.0.16/System.Linq.dll /usr/share/dotnet/shared/Microsoft.NETCore.App/8.0.16/System.Private.CoreLib.dll /usr/share/dotnet/shared/Microsoft.NETCore.App/8.0.16/System.Runtime.dll 2025-10-20 13:44:20 [RD-pc][root][ACT] The source code of scripts and formulas has been compiled successfully 2025-10-20 13:44:20 [RD-pc][root][ACT] Module ModArcBasic 6.2.0.0 loaded from file /opt/scada/ScadaServer/Mod/ModArcBasic.Logic.dll 2025-10-20 13:44:20 [RD-pc][root][ACT] Module ModArcPostgreSql 6.2.1.0 loaded from file /opt/scada/ScadaServer/Mod/ModArcPostgreSql.Logic.dll 2025-10-20 13:44:20 [RD-pc][root][ACT] Archive Cur initialized successfully 2025-10-20 13:44:20 [RD-pc][root][ACT] Archive Min initialized successfully 2025-10-20 13:44:20 [RD-pc][root][ACT] Archive Hour initialized successfully 2025-10-20 13:44:20 [RD-pc][root][ACT] Archive Events initialized successfully 2025-10-20 13:44:20 [RD-pc][root][ACT] Start listener on port 10000 2025-10-20 13:44:20 [RD-pc][root][INF] Archive in DAT format: /opt/scada/Archive 2025-10-20 13:44:20 [RD-pc][root][INF] Archive copy in DAT format: /opt/scada/ArchiveCopy 2025-10-20 13:44:21 [RD-pc][root][ACT] Delete outdated data from the Min archive older than 2024/10/20 2025-10-20 13:44:21 [RD-pc][root][ACT] Delete outdated data from the Hour archive older than 2024/10/20 2025-10-20 13:44:21 [RD-pc][root][ACT] Delete outdated data from the Events archive older than 2024/10/20 2025-10-20 13:44:28 [RD-pc][root][ACT] Session with ID -8567776689079243990 created 2025-10-20 13:44:28 [RD-pc][root][ACT] Client 127.0.0.1 connected 2025-10-20 13:44:28 [RD-pc][root][ACT] Session with ID -7755861321725536353 created 2025-10-20 13:44:28 [RD-pc][root][ACT] Client 127.0.0.1 connected 2025-10-20 13:44:29 [RD-pc][root][ACT] User ScadaComm is successfully authenticated 2025-10-20 13:44:29 [RD-pc][root][ACT] Session with ID -9120833948422862970 created 2025-10-20 13:44:29 [RD-pc][root][ACT] Client 127.0.0.1 connected 2025-10-20 13:44:29 [RD-pc][root][ACT] User ScadaComm is successfully authenticated 2025-10-20 13:44:30 [RD-pc][root][ACT] Client 127.0.0.1 disconnected 2025-10-20 13:45:09 [RD-pc][root][ACT] Session with ID -6124496869083433959 created 2025-10-20 13:45:09 [RD-pc][root][ACT] Client 127.0.0.1 connected-
This reply was modified 1 year, 1 month ago by
October 20, 2025 at 2:30 pm #17194
The Server service may start longer than the Webstation app and the Communicator service. The client applications try to connect Server while is it initializing. If they connect successfully after several attempts, it’s OK.October 20, 2025 at 2:33 pm #17195
MikhailModeratorError checking server connection:
Unable to write data to the transport connection: Permission denied.This error looks weird.
Does Communicator have any connection issues?October 21, 2025 at 1:09 am #17197123
ParticipantThe following is the report content of the Communicator?
But if I go to the /opt/scada directory and first execute scadastop.sh, then execute scadastart.sh to start it normally.ScadaComm.txt
Communicator
Started : 2025/10/20 下午1:44:17
Execution time : 00:03:04
Status : Normal
Version : 6.2.0.1Data Sources (1)
[ScadaServer] Server Data Source : ReadyServer Data Source
Connection : Logged In
Current data queue : 0 of 1000, skipped 0
Historical data queue : 0 of 1000, skipped 0
Event queue : 0 of 1000, skipped 0Communication Lines (2)
[1] RDW6000 : Normal
[2] 定值 : NormalScadaComm.log
2025-10-20 13:44:17 [RD-pc][root][ACT] Communicator 6.2.0.1 started
2025-10-20 13:44:17 [RD-pc][root][ACT] Storage FileStorage 6.2.0.0 loaded from file /opt/scada/ScadaComm/FileStorage.dll
2025-10-20 13:44:17 [RD-pc][root][ACT] 启动逻辑处理
2025-10-20 13:44:17 [RD-pc][root][ACT] Driver DrvCnlBasic 6.1.0.1 loaded from file /opt/scada/ScadaComm/Drv/DrvCnlBasic.Logic.dll
2025-10-20 13:44:17 [RD-pc][root][ACT] Driver DrvDsScadaServer 6.0.1.1 loaded from file /opt/scada/ScadaComm/Drv/DrvDsScadaServer.Logic.dll
2025-10-20 13:44:18 [RD-pc][root][ACT] Driver DrvModbus 6.0.0.4 loaded from file /opt/scada/ScadaComm/Drv/DrvModbus.Logic.dll
2025-10-20 13:44:18 [RD-pc][root][ACT] Data source ScadaServer initialized successfully
2025-10-20 13:44:18 [RD-pc][root][ACT] Data source ScadaServer: Receive the configuration database
2025-10-20 13:44:18 [RD-pc][root][ERR] Data source ScadaServer: Error checking server connection:
2025-10-20 13:44:18 [RD-pc][root][ERR] Unable to start communication lines because the configuration database is not received
2025-10-20 13:44:28 [RD-pc][root][ACT] Data source ScadaServer: Receive the configuration database
2025-10-20 13:44:29 [RD-pc][root][ACT] Data source ScadaServer: The configuration database has been received successfully
2025-10-20 13:44:29 [RD-pc][root][ACT] Start communication lines
2025-10-20 13:44:29 [RD-pc][root][ACT] Start reading commands from files
2025-10-20 13:44:29 [RD-pc][root][ACT] Data source ScadaServer: Connection state is Logged InOctober 21, 2025 at 9:14 am #17199
MikhailModeratorMy knowledge of Linux, unfortunately, is not enough to answer the question of why an error occurs when the system starts:
Another unknown thing, why the same error does not occur for Communicator.
What Linux version is used? -
