Some channels muted in Notifications
Forum Home › Forums › Understanding the Software › Some channels muted in Notifications
  • #17219
    WayneS
    Greetings,
    While playing with Limits and Notifications I have managed to ‘mute’ some channels, i.e. they no longer create notifications, while other channels continue to work correctly. Is there a way to unmute or reset this?
    regards
    Wayne
    #17222
    Notification Plugin creates notification based on events that require acknowledge.
    I suggest to compare corresponding events in the bottom event panel to find differences between the events that cause notifications and other events.
    #17233
    WayneS
    Hi Mikhail,
    For unknown reasons some channels seem not to generate events. The only way I found to fix this was to delete the channel, then recreate it with exactly the same definition and this allowed the limits to generate events. Note varying channel past the limit changed its colour, but didn’t generate and event.
    regards
    Wayne
    #17235
    Creating a channel is just writing its properties into the XML file.
    To find a cause, it would be useful to analyze the channel properties and events.
