Add to the Scripts table:
public string GetPayload() { return "{\"tagId\":\"pump1\",\"value\":" + CmdVal + "}"; }Then use GetPayload() as an output formula of the channel.
Let me know if it works or not.
Unfortunately no. It is always from 0:00 to 23:59.
May be the Rolling mode can be useful to display 24 hours from current time.
MikhailModeratorPlease provide a correct link to a screenshot. I deleted the incorrect link.
Thank you for the detailed description. There is no such feature to specify exact time. Only date selection is supported.
MikhailModeratorIt is very useful!
December 18, 2023 at 9:21 am in reply to: Whether the color of the enumeration can be modified #13835
In Rapid SCADA 6 you can set colors for enumerations in the Formats table. See Normal-Error row for example.
The next step is I just enable those archives with ModArcPostreSql module then Rapid SCADA will start storing data into PostgreSql database already, right?
Yes, if default settings are used. You should select data from the database table to make sure that data exist.
To select particular time period in Chart Pro, you should click and hold a left mouse button, then move the mouse to select the required period of time.
Please make a screenshot of the received data and provide an example what data you need to extract.
MikhailModeratorMy vision is that the solution can include a new database schema and the custom web forms built in the Webstation application as a web plugin. It requires development that is not a part of the Rapid SCADA core.
We update keys from v5 to v6 on the same machine for free.
Common license terms are also work, please check this link.
The Channels table has the particular number fields. To add new properties related to channels, I suppose, an additional database table should be added to implement customer needs.For example, you create a database schema using PostgreSQL, and develop web UI to edit it. Your data would refer Rapid SCADA channels.
Try pressing Shift + F5 or Ctrl + F5 in browser to refresh.
Open the Schemas node and check what schemas are available. You should find data there.
Thank you for the info. -
