Don’t display some events
Forum Home › Forums › Understanding the Software › Don’t display some events
  • #13364
    quintelosky
    Hi everybody
    I have a problem with events. The scada (v6.1.1) don’t display some events
    Tag:
    https://ibb.co/F3qwqxY
    Limit (ExtremelyHigh to 0)
    https://ibb.co/ZMB2FKY
    Event activated: 0 – event enabled, 4 – channel status
    https://ibb.co/JkXjBPB
    Value = 1,0
    https://ibb.co/sJLtHV8
    No event displayed
    https://ibb.co/9wKBP5c
    What could be happening?
    I have other events in enterprise object and works fine, but I have more objects in my scada and don’t work in other objects. I’m testing with a script to change status channel and that works, but using limits definition, no effect.
    • This topic was modified 3 years, 1 month ago by quintelosky.
    #13375
    According to the settings, events should be generated when channel status has changed. Does the channel status change when you change channel value from -1 to 1, for example?
    Next time, please make screenshots in English.
    #13390
    quintelosky
    Hi
    I created a script to force channel status
    https://ibb.co/hsf4K0b
    https://ibb.co/LDwh6sP
    And nothing. Is it possible that tag data type affect?
    https://ibb.co/0sC86FC
    If I create a new tag ‘calculated’ with formula Val(10436) and limits, works fine the new tag
    #13415
    Instead of that formula, use Cnl; 15 which fits for channel of the Input/output type.
    #13812
    quintelosky
    Hi
    Sorry for the delay
    The problem was I didn’t activate ‘Event archive’ in Archives
    Now works fine
    #13816
    Thank you for the info.
