ChartPro custom period
Forum Home › Forums › Understanding the Software › ChartPro custom period
  • #13829
    kcks66
    Hi Mikhail,
    I am using chartpro v6 and I want to choose certain start time and end time, but the custom period only allow me to choose start date and end date:
    https://ibb.co/b5xD2fg
    I see the historical data report can choose start time and end time:
    https://ibb.co/L8K6Gvm
    Pls advice for how to enable the start time and end time for chartpro custom period?
    #13833
    To select particular time period in Chart Pro, you should click and hold a left mouse button, then move the mouse to select the required period of time.
    #13837
    kcks66
    Hi Mikhail,
    I meant I want to choose the start time and end time together with the dates exactly just like the historical data report style, then the chart trend shall show the X-axis time period according to the start date start time and end date end time automatically.
    Example I wish to choose from 17/12/2023 07:00 AM to 18/12/2023 07:00 AM. Then the chart trend the data from 17/12/2023 07:00 AM to 18/12/2023 07:00 AM automatically.
    Pls advice for the chartpro can be configured to work like this?
    #13838
    Thank you for the detailed description. There is no such feature to specify exact time. Only date selection is supported.
    #13839
    kcks66
    Hi Mikhail,
    If this this the case, can I configure the ChartPro starting time always start from 7am and end 7am the next day?
    Currently the default start time is always start from 0:00 and end 23:59.
    Pls advice and thank you.
    #13847
    Unfortunately no. It is always from 0:00 to 23:59.
    May be the Rolling mode can be useful to display 24 hours from current time.
    #13856
    kcks66
    Hi Mikhail,
    Noted. Looks like I shall get used to the method:
    “click and hold a left mouse button, then move the mouse to select the required period of time”
