Add custom field to chanel
Forum Home Forums Understanding the Software Add custom field to chanel
  • #13815
    LouisC
    Hi!
    I wonder if there is a way to enter custom values into chanels. More precisely, my client would like to add a description for each chanel (in addition to name, format, etc…), and eventualy other specific fields in the future.
    Can we do it with Scada Admin ? If not, is it in the development roadmap ?
    #13819
    The Channels table has the particular number fields. To add new properties related to channels, I suppose, an additional database table should be added to implement customer needs.
    For example, you create a database schema using PostgreSQL, and develop web UI to edit it. Your data would refer Rapid SCADA channels.
    #13820
    LouisC
    Thank you for your answer. So to do this, I’m forced to find a way outside Rapid Scada ?
    #13826
    My vision is that the solution can include a new database schema and the custom web forms built in the Webstation application as a web plugin. It requires development that is not a part of the Rapid SCADA core.
