MikhailModerator1. Find and stop the application that uses port 10000.
2. Install Rapid SCADA.
3. Change TCP port used by Rapid SCADA.
4. Start the app that uses port 10000.OR
1. Change the port of that app that uses port 10000.
Please check the error details in ScadaWeb.log
MikhailModeratorCool!
November 4, 2024 at 7:44 am in reply to: Hello World Tutorial – “The requested view is not specified” #15568
MikhailModeratorOK
MikhailModeratorRapid SCADA supports MQTT out of the box.
MikhailModeratorPublished at https://rapidscada.net/store/Module/en/ExtScriptCompilerJP
Kepware should support Bacnet. However, you should look for less expensive alternative.
MikhailModeratorHow the new software module will be related with Rapid SCADA?
More info is needed to answer your question.
In this case you can write data to the archive on change. A timer will not provide such accuracy.October 22, 2024 at 11:17 am in reply to: Rapid SCADA 6.3.1 Installation, TCP port 10002 already in use. #15543
You can change the TCP port of the ScadaAgent service after installation.
Before starting installation, switch off KT Kernel & System.
I suppose, writing a script on your favorite language.
MikhailModeratorRapid SCADA 6.3.1 has been released.
What’s new:
– The ExtExternalTools extension has been developed for the Administrator application. The extension is designed to launch external applications. After updating, activate and configure the extension. Please ask clarifying questions in a separate thread.
– Minor bugs have been fixed.Details are available in the version history.
October 15, 2024 at 10:04 am in reply to: Seeking Guidance on Rapid SCADA Configuration for Real-Time Monitoring #15522 -
