Forum Home › Forums › Installation Issues › New release Rapid SCADA 6.3.x
- This topic has 6 replies, 3 voices, and was last updated 2 years ago by
August 13, 2024 at 1:38 pm #15123
MikhailModeratorRapid SCADA 6.3.0 has been released.
The update affected most applications and modules.Significant changes:
Server:
– Added historical archive options to shift a writing time relative to the period.
– The historical data format (*.dat) has been updated. Backward compatibility is provided.Administrator:
– Added useful tools such as Object Editor and Right Matrix.
– The Refresh and Find buttons have been moved to the main toolbar.Important!
If additional modules are used, they must be updated. Otherwise, there is a risk of damaging the project configuration files. Make backup copies of projects and use GIT repositories to store them.Check Version history for more details.
For module developers: rebuild your modules and, if necessary, update the arguments of the methods of common classes used.August 20, 2024 at 3:15 am #15171zzz
ParticipantHi Mik, does updating from 6.1 to 6.3 require data imigration ? If so are there toolds for this ?
This reply was modified 2 years, 2 months ago by
zzz.
August 20, 2024 at 8:03 am #15173long.ptsco
ParticipantHi Mik,
Please guide me: How to pack souce rapidscada code project to installation .exe file setup ?
Thankyou !August 20, 2024 at 9:18 am #15174
Projects are compatible. Project migration is not needed.
Build the source code according to the instructions. Then copy the files from your build output to the necessary folders.
August 21, 2024 at 9:17 am #15187zzz
ParticipantProjects are compatible. Project migration is not needed.
What about the data archives ?
Will a in-place dotnet binary update do ?August 21, 2024 at 11:18 am #15190
MikhailModeratorBackward compatibility is provided for data archives.
You need to update all files, not only binaries.October 15, 2024 at 10:19 am #15524
MikhailModeratorRapid SCADA 6.3.1 has been released.
What’s new:
– The ExtExternalTools extension has been developed for the Administrator application. The extension is designed to launch external applications. After updating, activate and configure the extension. Please ask clarifying questions in a separate thread.
– Minor bugs have been fixed.Details are available in the version history.
