Rapid SCADA 6.3.1 Installation, TCP port 10002 already in use.
Forum Home Forums Installation Issues Rapid SCADA 6.3.1 Installation, TCP port 10002 already in use.
  • #15540
    mesapat
    I have try to install Rapid SCADA 6.3.1
    and got this error. from my Windows 11 Home
    Check TCP port 10000
    TCP port 10000 is available.
    Check TCP port 10002
    Installation has completed with errors
    And Port 10002 use by KT Kernel & System (can not change to another port)
    how i can do next???
    #15541
    Change the ScadaAgent port to another one other than 10002
    <?xml version="1.0" encoding="utf-8" ?>
    <ScadaAgentConfig>
      <ListenerOptions>
        <Port>10002</Port>
    See the configuration file in the ScadaAgent\Config folder. After that, restart the services.
    Also, when configuring the configuration, specify this port in the project Instances
    • This reply was modified 1 year, 5 months ago by manjey73.
    #15543
    You can change the TCP port of the ScadaAgent service after installation.
    Before starting installation, switch off KT Kernel & System.
