Sending commands from Rapid SCADA to OpenPLC
Forum Home Forums Communicating with Devices Sending commands from Rapid SCADA to OpenPLC
  • #15519
    yousef
    I have been working on configuring Rapid SCADA to send simple commands, such as starting and stopping OpenPLC, but I have not yet been able to figure out the correct approach.
    Could you kindly provide guidance or details on how to successfully send these commands from Rapid SCADA to OpenPLC?
    Thanks,
    Yousef.
    #15521
    Does the OpenPLC use Modbus or another communication protocol?
    #15523
    yousef
    Yes, OpenPLC is using the Modbus protocol to communicate with Rapid SCADA.
    #15525
    I recommend the video about configuring Modbus. Then ask specific questions.
    #15526
    It seemed to me that the start and stop of the PLC is not related to the protocol, it is a higher level.
    But it can also be solved through protocol variables, but for this your PLC program must be written accordingly. These are fundamentally different approaches.
    #15527
    In a simple version, you can control it through the start variable
    In this case, the PLC does not actually stop, it does the work of “Doing nothing”
    if (start)
    { Your program }
    else do nothing
