Implementing chirpstack app with RapidScada
Forum Home › Forums › Development and Integration › Implementing chirpstack app with RapidScada
  • #15547
    Jorge
    Hi all, i am new with RapidScada and i want to implement a chirpstack app, this software lets you integrate influxDB and more.
    my question is, is it possible? i am learning how to use RapidScada so i have no further knowleg
    #15550
    JurasskPark
    And what programming language do you want to implement in? I have not found any examples of Chirpstack in C#.
    #15551
    But there is a gateway-bridge and a rest api that can be used when writing a driver or module. And you can also try importing from Influxdb
    #15552
    More info is needed to answer your question.
    #15555
    Jorge
    Thanks to all of you for answering, this was sort of an ask first read later situation. Chirpstask is an open source LoRaWAN server software that lets you implement HTTP, MQTT, AWS SNS, Azure Service-Bus, GCP Pub/Sub, IFTTT, InfluxDB, myDevices, Pilot Things, Semtech LoRa Cloud™, ThingsBoard to the server rather easily.
    For the moment, I will try to implement influxDB.
    If you have any suggestions, you are welcome to share them.
    I am also going to keep updating this thread if I have good results.
    #15556
    JurasskPark
    You haven’t answered the question. What programming languages do you know and how do you want to integrate? Through libraries or the web (api)?
    #15557
    How the new software module will be related with Rapid SCADA?
    #15560
    Jorge
    I was looking at the possibility of using an MQTT broker, ChirpStack comes with one [MQTT]
    #15561
    Rapid SCADA supports MQTT out of the box.
