Error when download report
Forum Home Forums Understanding the Software Error when download report
  • #15564
    kcks66
    Hi Mikhail,
    I tried to download one month data report but error happened.
    https://ibb.co/s3N0RZP
    Elastic Report with 30 channels from minute achieve. FYI, I am using PostgreSQL as my default storage type, and PC storage is SSD type.
    If I tried to download for 10 days period it’s success but slow. Pls advice for any solutions. Thank you.
    • This topic was modified 1 year, 9 months ago by kcks66.
    #15570
    Please check the error details in ScadaWeb.log
    #15571
    kcks66
    Hi Mikhail,
    Error detail as below.
    2024-11-04 15:47:55 [WIN-HHIJ7MIVESP][WIN-HHIJ7MIVESP$][ERR] Unhandled exception:
    Scada.ScadaException: Error building model of section Section1
    —> System.IO.IOException: Unable to read data from the transport connection: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond..
    —> System.Net.Sockets.SocketException (10060): A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
    at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 count)
    at Scada.Client.ClientBase.ReceiveResponse(DataPacket request)
    at Scada.Client.ScadaClient.GetTrends(Int32 archiveBit, TimeRange timeRange, Int32[] cnlNums)
    at Scada.Web.Plugins.PlgElasticReport.Builder.ModelBuilder.TimeDataSectionBuilder.Build(TimeDataSectionConfig sectionConfig)
    at Scada.Web.Plugins.PlgElasticReport.Builder.ModelBuilder.DocumentBuilder.Build(ReportConfig reportConfig, ElasticReportArgs reportArgs, BuilderOptions builderOptions)
    at Scada.Web.Plugins.PlgElasticReport.Builder.ElasticReportBuilder.Generate(ElasticReportArgs args, Stream outStream)
    at Scada.Web.Plugins.PlgElasticReport.Controllers.PrintController.PrintReport1(Int32 reportID, DateTime startTime, DateTime endTime, String archive, OutputFormat format, IntRange cnlNums)
    at lambda_method215(Closure, Object, Object[])
    at Microsoft.AspNetCore.Mvc.Infrastructure.ActionMethodExecutor.SyncActionResultExecutor.Execute(ActionContext actionContext, IActionResultTypeMapper mapper, ObjectMethodExecutor executor, Object controller, Object[] arguments)
    at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.InvokeActionMethodAsync()
    at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.Next(State& next, Scope& scope, Object& state, Boolean& isCompleted)
    at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.InvokeNextActionFilterAsync()
    — End of stack trace from previous location —
    at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.Rethrow(ActionExecutedContextSealed context)
    at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.InvokeInnerFilterAsync()
    at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.<InvokeNextResourceFilter>g__Awaited|25_0(ResourceInvoker invoker, Task lastTask, State next, Scope scope, Object state, Boolean isCompleted)
    at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.Rethrow(ResourceExecutedContextSealed context)
    at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.Next(State& next, Scope& scope, Object& state, Boolean& isCompleted)
    at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.InvokeFilterPipelineAsync()
    at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.<InvokeAsync>g__Awaited|17_0(ResourceInvoker invoker, Task task, IDisposable scope)
    at Microsoft.AspNetCore.Session.SessionMiddleware.Invoke(HttpContext context)
    at Microsoft.AspNetCore.Authorization.AuthorizationMiddleware.Invoke(HttpContext context)
    at Microsoft.AspNetCore.Authentication.AuthenticationMiddleware.Invoke(HttpContext context)
    at Microsoft.AspNetCore.Diagnostics.ExceptionHandlerMiddlewareImpl.<Invoke>g__Awaited|10_0(ExceptionHandlerMiddlewareImpl middleware, HttpContext context, Task task)
    #15580
    According to the log file, the web app cannot receive data from the SCADA-Server service. May be data is too large. How many data points do you expect for that report and period of time?
    #15581
    Try create similar report that retrieves data from *.dat archives based on files.
    #15582
    kcks66
    Hi Mikhail,
    I have 30 channels and download report with one minute interval for one month period, thus:
    data points = 60 (minutes) X 24 (hours) X 31 (days)
    = 44,640
    Should I 44,640 X 30 (channels)?
    Unfortunately I don’t have setup that can repeat the report dowloading with the same data points in *dat achieve.
    • This reply was modified 1 year, 9 months ago by kcks66.
    #15587
    Yes.
    Try increasing ConnectionOptions – Timeout in ScadaWebConfig.xml. Are you able to get more data with bigger timeout?
    #15588
    kcks66
    Hi Mikhail,
    That’s great. I managed to download the report. The report size is 181MB.
    I changed the Timeout to 20000.
    #15589
    It’s big 🙂
