Viewing 15 posts - 766 through 780 (of 6,287 total)
  • in reply to: JS file debug in MQTT integration #15635
    Use the log function as shown here.
    in reply to: install Plugin #15633
    I have my ‘own’ project, so not hello world from the installation process. Does this mean that the files have to be copied to a different location?
    ChartPro*.xml files should be copied in your project folder (where you saved it) as shown in the above post.
    • This reply was modified 1 year, 7 months ago by Mikhail.
    in reply to: Map Plugin not success #15631
    Copy PlgMap.xml from the distributive package to your project. Then upload the project again.
    in reply to: Hourly countdown formula #15615
    Thank you for the update.
    in reply to: Hourly countdown formula #15611
    Formulas of the calculated channels are called many times a second.
    Formulas of the input channels are called when data comes from Communicator. By default, Communicator sends all device data every minute. May be this is the cause.
    For what channel number do you use the function Timer48hactief?
    in reply to: Hourly countdown formula #15607
    Set status to 0 by the 2nd part of the formula. Docs
    in reply to: Conecction wirh DNP3 #15606
    How to connect a device that only supports DNP3?
    Could a Modbus-DNP3 gateway be an option? What else is there?
    Use a 3rd party OPC server or a hardware gateway.
    in reply to: Default start page after login #15592
    Try, for example:
    /View/1
    or
    ~/View/1
    where 1 is a view ID.
    in reply to: Error when download report #15589
    It’s big 🙂
    in reply to: Error when download report #15587
    > Should I 44,640 X 30 (channels)?
    Yes.
    Try increasing ConnectionOptions – Timeout in ScadaWebConfig.xml. Are you able to get more data with bigger timeout?
    in reply to: new csv file reder driver #15586
    That issue has been added to the backlog. If it is needed by a certain time, we could implement it for some fee. Otherwise, we will do it ourselves, but it is not known by what date.
    in reply to: Error when download report #15581
    Try create similar report that retrieves data from *.dat archives based on files.
    in reply to: Error when download report #15580
    According to the log file, the web app cannot receive data from the SCADA-Server service. May be data is too large. How many data points do you expect for that report and period of time?
    in reply to: ModArcPostgresql module can not connect Potgresql #15579
    PostgreSQL should be configured to allow password authentication. Check this link, for example.
    in reply to: Hourly countdown formula #15577
    The Timestamp variable is not available in v5. Use DateTime.UtcNow instead.
