Map Plugin not success
Forum Home › Forums › Installation Issues › Map Plugin not success
  • #15623
    bey
    Hi Mikhail,
    I have installed Map Plugin with trial regristration and extracted them to the directories. Configure views and saved and upload configuration. I get this error:
    2024-11-18 16:24:49 [DESKTOP-P8NT63V][DESKTOP-P8NT63V$][ACT] Plugin PlgMap 6.1.0.1 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgMap.dll
    2024-11-18 16:24:49 [DESKTOP-P8NT63V][DESKTOP-P8NT63V$][ACT] Plugin PlgScheme: Retrieve scheme components from the installed plugins
    2024-11-18 16:24:49 [DESKTOP-P8NT63V][DESKTOP-P8NT63V$][ACT] Plugin PlgScheme: Added components from the PlgSchBasicComp plugin
    2024-11-18 16:24:49 [DESKTOP-P8NT63V][DESKTOP-P8NT63V$][ACT] Check PlgMap registration: Registration key is valid. Expiration date is 19/11/2024.
    Computer code: =73896BCCB18D8C6A-21D74833779983E0-F245C56AFC519F15-D38BBCDB9AC270FC-B810EFB0B4D5946A-1DA18D4EBDFC9F12-BCC7B681EF22BAAD-50BCC8EC5B537845-97A9D26274F9C71B-3DFCABC64B538121-56A048262E1F93BD-DC49C7FDDD1CCAC3-A98F28AFD720235E-ABB404E19FDB7008-E3D7599C9C988AA2-0A64ECD8F678DC27=
    Registration key: A5EAA52AA12194CC-4DBDAE990536B2F7-E647973EDB689958
    2024-11-18 16:24:49 [DESKTOP-P8NT63V][DESKTOP-P8NT63V$][ERR] Plugin PlgMap: Error loading configuration:
    Could not find file ‘C:\Program Files\SCADA\ScadaWeb\config\PlgMap.xml’.
    2024-11-18 16:24:49 [DESKTOP-P8NT63V][DESKTOP-P8NT63V$][ACT] Receive the configuration database
    And when I after upload configuration, file MapExample.map on SCADA/Views and file PlgMap.xml on SCADA/ScadaWeb/config are missing
    Is there any steps that I missed?
    #15624
    After installing any plugin, you first need to upload the Server Configuration to the project.
    This is probably why you do not have a configuration file, since you have transferred a project in which this file does not exist yet, it is only in the web part after copying the plugin.
    #15631
    Copy PlgMap.xml from the distributive package to your project. Then upload the project again.
