Forum Home › Forums › Installation Issues › install Plugin
- This topic has 14 replies, 4 voices, and was last updated 11 months, 1 week ago by
November 16, 2024 at 4:39 pm #15619
fischerp
ParticipantHello,
First the version. I am working with RS 6…(the latest one)
I would like to install chart pro. I have downloaded the plugin and copied the files into the appropriate folders (as specified in the package). There is a dll that is not blocked, I have checked that.
Now it should be possible to activate the plugin in the Administrator – Server – Module. It does not appear in the list of currently inactive modules.
I have my ‘own’ project, so not hello world from the installation process. Does this mean that the files have to be copied to a different location?
I deliberately did not change the ports during the installation, so I call Rapid Scada .it x.x.x.x.x:10008, for which it was necessary to release port 10008 in the firewall. Does this have any influence on the installation of the plugin?
Many thanks for any tips.-
This topic was modified 2 years ago by
November 17, 2024 at 6:59 am #15620
manjey73ParticipantCopy the plugin to the runtime server, as well as to your PC, where you are developing. Then you open your project (not necessarily Hello World) And download the configuration from the server to the project.
Then you add a plugin, and passes the configuration to the server. After that, you will have the opportunity to register – information about the PC key when the plugin starts on the server.November 17, 2024 at 7:01 am #15621
manjey73ParticipantThis is true for all plugins. In order for them to run, they must be copied to the runtime server and to the development server, as well as the runtime server configuration downloaded to the project.
November 18, 2024 at 9:39 am #15622fischerp
ParticipantNow I am a bit confused.
I have a Windows PC on which I have installed Rapid-Scada. This means that both the administration program (Administrator.exe) and Scada (all databases, Webvisu, server…) are on the same computer.
Here I have copied the files contained in the plugin into the respective folders of the same name. As recommended in the instructions, I have checked that all dlls are not not locked. In this case, this is only the PlgChartPro.View.dll in the folder Scada-ScadaAdmin_Lib.
In this context, I don’t understand the difference between the runtime server and the “PC on which I am currently developing”. From my point of view, this is just one device.
What do I understand wrong?November 18, 2024 at 12:10 pm #15625fischerp
ParticipantAfter I understood what the above meant, I got the plugin to work. However, there is still a small problem. The charts are black and white and I get the following error:
Error loading configuration: Could not find file
C:\Program Files\SCADA\ScadaWeb\config\PlgChartPro.xmlThe XML file should be generated automatically according to the instructions. What could have gone wrong? Or how can I fix it?
November 18, 2024 at 12:47 pm #15626
manjey73ParticipantProbably this file is not in the project – the Project folder for example HelloWord
November 18, 2024 at 12:49 pm #15627
manjey73ParticipantI’m telling you. You have copied all the plugin files according to the folders.
Then open your project and Download the Configuration.
The necessary settings files will be uploaded to the project.If you try to transfer the server Configuration, since you do not have the settings files yet, they will be deleted on the production server, regardless of whether you are working with the project on the same PC or on a remote one.
This reply was modified 2 years ago by
manjey73.
November 18, 2024 at 12:59 pm #15629
manjey73ParticipantNovember 18, 2024 at 1:00 pm #15630
manjey73ParticipantYou need to put the necessary configuration files in your project, which you then transfer to the Server. You can do this manually by finding the project folder.
November 18, 2024 at 1:19 pm #15633
ChartPro*.xml files should be copied in your project folder (where you saved it) as shown in the above post.
December 19, 2025 at 1:17 pm #17431tom040264
ParticipantHi guys,
I isntalled ChartPro, and got a tryal key. This the log after I uploaded the configuration.
2025-12-19 14:09:40 [linux-server][root][ACT] Webstation 6.2.2.0 started
2025-12-19 14:09:40 [linux-server][root][ACT] Storage FileStorage 6.4.0.0 loaded from file /opt/scada/ScadaWeb/FileStorage.dll
2025-12-19 14:09:40 [linux-server][root][ACT] Plugin PlgChart 6.1.0.1 loaded from file /opt/scada/ScadaWeb/PlgChart.dll
2025-12-19 14:09:40 [linux-server][root][ACT] Plugin PlgChartPro 6.1.1.0 loaded from file /opt/scada/ScadaWeb/PlgChartPro.dll
2025-12-19 14:09:40 [linux-server][root][ACT] Plugin PlgMain 6.1.1.1 loaded from file /opt/scada/ScadaWeb/PlgMain.dll
2025-12-19 14:09:40 [linux-server][root][ACT] Plugin PlgScheme 6.1.1.0 loaded from file /opt/scada/ScadaWeb/PlgScheme.dll
2025-12-19 14:09:40 [linux-server][root][ACT] Plugin PlgSchBasicComp 6.1.0.0 loaded from file /opt/scada/ScadaWeb/PlgSchBasicComp.dll
2025-12-19 14:09:40 [linux-server][root][ACT] Plugin PlgStore 6.1.0.1 loaded from file /opt/scada/ScadaWeb/PlgStore.dll
2025-12-19 14:09:40 [linux-server][root][ACT] Plugin PlgWebPage 6.1.1.0 loaded from file /opt/scada/ScadaWeb/PlgWebPage.dll
2025-12-19 14:09:40 [linux-server][root][ERR] Plugin PlgChartPro: Dictionary file not found: /opt/scada/ScadaWeb/lang/PlgChartPro.en-GB.xml
2025-12-19 14:09:40 [linux-server][root][ACT] Check PlgChartPro registration: Registration key is valid. Expiration date is 20/12/2025.
Computer code: =134A30AEEC340231-F8191A39CF5CE7E9-12A367C7CB8A86AE-4624F99D72D3BEA2-36C1B5C1A583257B-9332C3616C4CF5AD-5DF540FF6BC0ADD2-F7224C389E3EC74A-546D1AFB62238659-A46CD9573AADDBCE=
Registration key: A5B201D04E35A836-4CEF0864BA77710D-2E1FE3AD8E04BF1A
2025-12-19 14:09:40 [linux-server][root][ACT] Plugin PlgScheme: Retrieve scheme components from the installed plugins
2025-12-19 14:09:40 [linux-server][root][ACT] Plugin PlgScheme: Added components from the PlgSchBasicComp plugin
2025-12-19 14:09:41 [linux-server][root][ACT] Receive the configuration database
2025-12-19 14:09:41 [linux-server][root][ACT] The configuration database has been received successfully
2025-12-19 14:09:41 [linux-server][root][INF] The application is ready for operating——————————————————————————–
I can not see any problems or error messages in this log. But each time I click on one channel I get a popup window with a message “UNDEFINED”.
With normal Chart all channels will be displyed without any troubles.
Any idea?
Thx and br
T.
December 19, 2025 at 1:57 pm #17432
manjey73Participant2025-12-19 14:09:40 [linux-server][root][ERR] Plugin PlgChartPro: Dictionary file not found: /opt/scada/ScadaWeb/lang/PlgChartPro.en-GB.xmlIs everything copied?
Also, make it a rule to download from the server by installing the web plugin so that all configuration files are included in your project.December 19, 2025 at 1:59 pm #17433
Please open the developer tools in browser (press F12), and check if there any errors.
Also make sure that you selected PlgChartPro in the Webstation settings (in the Administrator app).December 20, 2025 at 9:15 am #17439tom040264
ParticipantI didn’t copy the folder Chart pro into the Folder
\opt\scada\ScadaWeb\wwwroot\plugins (at raspberry). Now it works.
Thenk you guys!
December 22, 2025 at 12:43 pm #17442
MikhailModeratorThank you for the update.
