Viewing 15 posts - 4,651 through 4,665 (of 6,290 total)
  • in reply to: Creating Redistributable Installer #4221
    Yes, this is a new question.
    I suggest this article http://doc.rapidscada.net/content/en/installation-and-run/manual-installation.html
    The described steps are particular the same as Rapid SCADA installer performs.
    in reply to: how to send a modbus value #4219
    Thank you for the screenshot. Currently, you should input a value in a popup window or create several buttons to set different values. Or both.
    in reply to: Adding link to chart view #4217
    Close button that is shown in fullscreen and kiosk mode will be implemented in the next version of Chart Pro plugin. In usual mode this button is hidden.
    in reply to: how to send a modbus value #4216
    Is there a way to use a control like a spinbox to send values to a device? Or am I required to use the popup implemented in the Schemes?
    Could you provide an example image of spinbox? If a value is a number, you should input it manally. However, you can create several buttons with different values.
    I know it may be a little to much to include in the same question, but is there a way (maybe with formulas) to limit the value to send with the value from other input channels?
    It’s better to create a new topic.
    Yes, use formula for an output channel.
    For example: Math.Max(Math.Min(Cmd, 10), 0)
    in reply to: OPC Server Connection – E_NETWORK_ERROR #4213
    Classic OPC is a black box, difficult to find a cause. Modbus is transparent.
    in reply to: Schedule function and screen editing alignment function #4211
    You can implement this using time triggers of Autmatic Control Module.
    And screen editing alignment function,moving coordinates is a bit time consuming.
    Could you clarify?
    in reply to: Showing zeros #4210
    You should open Administrator, open the Input channels table and change the Format field of the appropriate input channel.
    in reply to: Security and Software Research on Industrial Control Systems #4205
    I have contacted Positive Technologies.
    If you find it usefull, add me to email topics, related to Rapid SCADA, with Positive Technologies. It’s interesting.
    Would your company be interested in, at least, acting as testers or users of any vulnerability or software analyses we build for ICS/SCADA software?
    We are interested in improving Rapid SCADA and constantly do this. If you mean testing and using Rapid SCADA to analyse security, we would like to join. Because Rapid SCADA is open source, in case of large work we should think about commercial aspect too and possibly ask for sponsorship.
    in reply to: OPC Server Connection – E_NETWORK_ERROR #4204
    You can add me (info@…) to an email copy if needed.
    in reply to: Security and Software Research on Industrial Control Systems #4201
    Our company either develop Rapid SCADA software or create turn key configurations to deploy on locations. Talking about SCADA security, I suggest Positive Technologies. They are smart.
    in reply to: Data input #4200
    Till the end of this year )
    in reply to: OPC Server Connection – E_NETWORK_ERROR #4199
    Is it possible to contact a manufacturer of this OPC server? We could test the connection together. It may help to find the cause.
    Does this OPC server support OPC UA?
    in reply to: Not open ServerRoom.sch in Editor #4195
    To solve the issue the screenshots and log are needed. The log is located in C:\SCADA\ScadaSchemeEditor\Log
    Also check that your browser is up to date. Chrome, Firefox and Edge are supported.
    in reply to: localization Rapid SCADA into Italian language #4193
    Can you successfully switch to Italian language now?
    in reply to: Security and Software Research on Industrial Control Systems #4191
    Server, Communicator and Webstation are the runtime core of Rapid SCADA.
