Adding link to chart view
Forum Home Forums Development and Integration Adding link to chart view
  • #4115
    Avatararifertem
    Is it possible to add a link to chart view and table view.
    The web page runs in full screen(in kiosk mode) so it is not possible to return previous screen in chart view.
    Thanks.
    #4118
    MikhailMikhail
    I see.
    Quick solution is using a link component on a scheme and specify an URL to a chart.
    The best solution is updating the web application to support the appropriate option. This could be done on commercial base.
    #4119
    MikhailMikhail
    To use a link you need to update Rapid SCADA to the latest version.
    #4122
    AvatarFlipp00082
    You can edit /ScadaWeb/Plugins/Chart/Chart.aspx
    Add this line:
    <button onclick=”self.close()”>Close</button>
    Directly under the following line:
    <asp:Label ID=”lblGenDT” runat=”server” Text=””></asp:Label>
    This is exactly what you need for the kiosk-mode!
    #4125
    MikhailMikhail
    Interesting and simple.
    #4130
    Avatararifertem
    Thank you all.
    #4217
    MikhailMikhail
    Close button that is shown in fullscreen and kiosk mode will be implemented in the next version of Chart Pro plugin. In usual mode this button is hidden.
    #6106
    MerdockMerdock
    Hi, I make a correction to the command for the close button.
    The line that worked for me was this.
    <input type = “button” value = “close” onclick = “self.close();”>
    I hope I could have been helpful.
    Regards.
    #6114
    MikhailMikhail
    Now such button is implemented in Chart Pro.
