localization Rapid SCADA into Italian language Forum Home › Forums › Development and Integration › localization Rapid SCADA into Italian language This topic has 8 replies, 3 voices, and was last updated 8 years, 1 month ago by Mikhail. Viewing 9 posts - 1 through 9 (of 9 total) Author Posts March 6, 2016 at 3:57 pm #869 scodinaParticipant So tell me how, I use visual Studio for some projects, is that what I need to open and change source code? March 6, 2016 at 5:09 pm #871 MikhailModerator Visual Studio 2013 or higher. Community Edition is OK. March 6, 2016 at 5:12 pm #872 MikhailModerator You don’t need any programming for localization. Search for *.en-GB.xml files into C:\SCADA folder. You should create similar files for Italian. Then open SCADA-Administrator -> Settings -> Language and type your culture name. August 31, 2018 at 11:04 am #4181 quattrolabParticipant Hello, i’m new of Rapid Scada Community. My Scada version is 5.1.0.0, i have followed the instruction for localization in italian language, but when in SCAD-Adiministratio going to Settings and type language it show this error. “The Language is incorrect” I’ve olso restarted al services. How Can solve? Thank you! August 31, 2018 at 7:04 pm #4185 MikhailModerator Hi, If I understand you correctly, you are going to create Italian localization files? Right? Please provide some screenshots of the steps you did and the error message. September 1, 2018 at 5:14 pm #4188 quattrolabParticipant Hi, yes did you understand correctly! September 2, 2018 at 6:03 am #4189 MikhailModerator Hi, If you share the translation when it is ready, this would be cool! In the language text box just type: it-IT Language files must have xml extenstion. Does the Windows explorer hide file extensions? September 2, 2018 at 9:47 am #4192 quattrolabParticipant Hi, certainly, in the next weeks i will send you all translated files. September 3, 2018 at 5:00 am #4193 MikhailModerator Hi, Can you successfully switch to Italian language now? Author Posts Viewing 9 posts - 1 through 9 (of 9 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
