Could you explain the question and provide some examples?
It is possible simply copy the project folder to another machine. But it’s not comfortable to synchronize them.
I recommend a private repository on GitHub to exchange between different machines and control the project versions.If the 1st PC is a workstation, and the 2nd is a production server, you can upload the project from the 1st to the 2nd with the Administrator application for execution.
MikhailModeratorThere is no software limits. It depends on the computer and network performance.
Projects may include hundreds of communication lines.
MikhailModeratorThe browser can manage memory cleanup using its own algorithms.
1. What versions of the web browser do you use?
2. What was the maximum memory consumption achieved by the page?
2. In the Modbus template, add a new command, set the Data block to Custom, the function code to 7.
3. According to the Modbus specification, Input Registers are read-only. So it’s not possible to write them. You can try creating a separate command with the 0x06 code.
MikhailModerator> I was able to get your software to recognize an OPCUA server and its all working now.
That’s nice.> if I want to work on an project on one PC and then copy it over to another PC how do I do that?
Please create a separate topic for that question.
Yes, activate the OpcUaServer data source that can be found in Instances – Default – Communicator – Data Sources.-
This reply was modified 7 months, 1 week ago by
That problem has not been observed before.
What versions of the web browser and Rapid SCADA do you use?
It would be useful, but this is not possible for now. I saved the idea and will see what can be done. I plan to return to work on the new editor in January.
Creating a channel is just writing its properties into the XML file.
To find a cause, it would be useful to analyze the channel properties and events.
MikhailModerator> So if this issue occurs, should we address it or simply ignore it?
If the issue is not visible to a user, it can be ignored.
MikhailModeratorSystem requirements are here.
Minimum Windows 10.Can I connect to it using Rapidscada to access the OPC data on that machine?
Likely, yes.
If you have any issues, please contact us.October 27, 2025 at 10:43 am in reply to: Is there a better way to batch modify channel attributes? #17225
MikhailModeratorIn the Administrator app, select Tools – Project Tools – Export Table. Then select an output format, and channels to export.
Do the errors occur when a new table view is open, or when a table view is unloaded?
Also please make a screenshot of the error requests in the Network tab. -
