multi channel support needed in mimiceditor
Forum Home › Forums › Development and Integration › multi channel support needed in mimiceditor
  • This topic has 4 replies, 2 voices, and was last updated 1 year ago by Zeus.
  • #17255
    Zeus
    I am trying to develop plugin. And i don’t know how to make plugin support more than one channel.
    #17259
    Could you explain the question and provide some examples?
    #17260
    Zeus
    Hi.
    The RegularComponentDescriptor have PropertyDescriptor below. It supports only one cnl
    this.add(new PropertyDescriptor({
    displayName: “Input channel”,
    category: KnownCategory.DATA,
    type: BasicType.INT
    And the function below bind cnl in xml
    /// <summary>
    /// Binds the view to the configuration database.
    /// </summary>
    public override void Bind(ConfigDataset configDataset)
    foreach (Component component in Mimic.EnumerateComponents())
    if (component.Bindings != null)
    component.Bindings.BindChannels(configDataset);
    component.Bindings.OffsetCnlNums(viewArgs.CnlOffset);
    component.Bindings.GetAllCnlNums().ForEach(cnlNum =>
    AddCnl(configDataset.CnlTable.GetItem(cnlNum)));
    Now i am developing mimic plugin it need more than one cnl. I don’t know how to make a PropertyDescriptor support more than one cnl and it can bind.
    #17264
    The Input channel property is used for simple scenarios. To bind many properties to different channels, click the Property bindings button (in the property grid) and add as many bindings as needed.
    Please translate this document from Russian into your native language. It can help.
    #17266
    Zeus
    It works. thanks
