The described features would be quite useful, definitely. Many of them are contained in our back log. General direction of improvements is making scheme editing faster.
Some features are already exist, at least partially:
> Select multiple elements at ones
Hold Ctrl and click elements.> The ability to define a detailed view for an element, for instance double-click on element to display a popin with informations regarding this element
Link component allows to show a popup. Note: double click is not common in web interface.Is there a RapidSCADA developper based in western europe ?
Our team is located in Voronezh, Russia. Rapid SCADA community is around the world.
This year we plan to release Rapid SCADA 6 with the existing scheme engine. The 6th version simplifies project configuring and data archiving.
Next year it would be nice to significantly redesign schemes to add new features.
We would be glad to cooperate.-
This reply was modified 4 years, 1 month ago by
Scheme Editor is in the ScadaScheme solution.By the way, what changes are you going to make?
MikhailModerator🙂
MikhailModeratorThere is another version of InfluxDB module for Rapid SCADA 6 Beta. You could try.
Action=Send Command
You need to create an output channel that uses SetVal formula and set the Output channel property of the button.
A number is entered in a popup window.
MikhailModeratorDefinitely, PlgNotification will be ported to v6.
For now, I can’t provide particular due date.
MikhailModeratorDear Matt,
You could add the 2nd export target to the module settings.
Screenshots would help.
@q383186554, could you reply?May 1, 2022 at 7:12 am in reply to: Schematic can not display on web browser for Rapid SCADA 5.8.4. #10240
Thank you for the information how the issue was solved.
You should clear the browser cache after updating Rapid SCADA to a new version.
To do that, open the web app and press Ctrl+F5 or Shift+F5 (depending on browser).
MikhailModerator🙂
MikhailModeratorLooks like the Agent service is not working.
Check C:\SCADA\ScadaAgent\Log\ScadaAgent.log
Restart the PC to start the service.
Please create a new topic in this subforum and provide the error details.
MikhailModeratorIt means that IIS can’t start.
Check the TCP port 80 if it is in use by another app.April 26, 2022 at 6:36 am in reply to: The requested view does not exist or you have insufficient rights to access it. #10224
Try adding a record:
ID=4
Path=Modbus_Unity\Then upload the project for executing.
Does it help?
If no, check the log file C:\SCADA\ScadaWeb\log\ScadaWeb.log -
