Entering number from browser
Forum Home › Forums › Understanding the Software › Entering number from browser
  • #10253
    kcks66
    Hi Mikhail,
    I wish to enter number from web browser (button) and store into an input channel (112). I tried but nothing happened. My configuration as below.
    https://ibb.co/XfPNM3z
    Pls advice and thank you.
    #10254
    use Formula SetVal
    Look in the documentation how to use it correctly
    #10255
    Action=Send Command
    You need to create an output channel that uses SetVal formula and set the Output channel property of the button.
    A number is entered in a popup window.
    #10257
    JW
    You will need to create an extra output channel to do that.
    https://rapidscada.net/doc/content/latest/en/software-configuration/using-formulas.html
    Create an output channel, maybe also use same channel number 112 as follow
    Command Type: Standard
    Formula Used: True
    Fomula: SetVal(112,Cmd)
    Button settings
    Action: Send command
    Input Channel: empty
    Output Channel: 112
    #10258
    kcks66
    Hi Mikhail, manjey73 & JW,
    It worked. Thank you.
    #10259
