Schematic can not display on web browser for Rapid SCADA 5.8.4.
Forum Home Forums Runtime Bugs Schematic can not display on web browser for Rapid SCADA 5.8.4.
  • #10231
    Rojer
    Hi , I’m new guy to study the ” Rapid SCADA ” . I installed the last version 5.8.4 when installation finish , may be display some error
    ” Check the configuration of Internet Information Services (IIS)
    Go to
    Control Panel > Programs > Turn Windows features on or off
    and make sure that WCF Services > HTTP Activation feature is installed for .NET Framework 4+,
    whereas the components for .NET Framework 3.5 are switched off
    Check Windows Communication Foundation (WCF)
    Register ASP.NET ”
    and I restart my computer after that I run the “Administrator” I found every quite ok . I opened the “demo project” and I found that the Schematic which display on design mode can not display or empty page . I try a hundred times to uninstall and run program but every same before. anyone can recommence me?
    #10233
    Rojer
    As shown on picture.
    None Schematic Display on Rapid SCADA 5.8.4
    • This reply was modified 1 year, 1 month ago by Rojer.
    #10237
    Rojer
    Anyone , I just to find the problem , It came from the cache of Microsoft Edge .
    After I clear them , the schematic come back , However I think the problem will be back again after we run the program for long time . what do you think?
    Rojer
    #10240
    Thank you for the information how the issue was solved.
    You should clear the browser cache after updating Rapid SCADA to a new version.
    To do that, open the web app and press Ctrl+F5 or Shift+F5 (depending on browser).
