Forum Home › Forums › Uncategorized Issues › OPC DA
- This topic has 5 replies, 2 voices, and was last updated 4 years, 6 months ago by
March 24, 2022 at 11:56 pm #10119
alex19rc
ParticipantHello, I hope you can support me.
I have LACROIX SOFREL telemetry equipment, which can be integrated with different SCADAs via SOFREL’s OPCServer. I am trying to read 2 pieces of information from an RTU.
I don’t know if this way of reading information is generic, but when I integrate SOFREL systems with SCADAs from another manufacturer. In the device configuration, where I indicate the source of the information I want to read at the end of the path, I add the variable number in parentheses. For example:
http://file:///C:/Users/Alejandro%20Rangel/Documents/Personal/NOM/Elementos%20APK/Captura.MHT Device 1 Configuration.
Can you tell me how I can do this process, since the route that Rapid Scada takes me is as follows (next image), and thus I obtain all the information from the RTU and Rapid Scada does not allow me to process it.
src=”http://file:///C:/Users/Alejandro%20Rangel/Documents/Personal/NOM/Elementos%20APK/Lista%20de%20informaciones.MHT” alt=”Current device tags” />
AS50_PRUEBA/S500/NI/Value-
This topic was modified 4 years, 7 months ago by
March 25, 2022 at 7:54 am #10124
Please upload screenshots to some cloud drive to be able to see them.March 30, 2022 at 5:52 pm #10143alex19rc
ParticipantSorry, I did not realize that the images had not been uploaded correctly.
https://drive.google.com/drive/folders/1NllYD0wpfe8fyycSAjaOCSDgV1tCf-RR?usp=sharing
I also have doubts about the ability of Rapid SCADA to communicate by standard DNP3 or IEC-60870-5/-104 with RTUs
March 31, 2022 at 2:58 pm #10144
MikhailModeratorIf the required value is array, you should set an array length.
Channel names entered in the configuration database have no effect how Communicator reads data from the OPC server.Does the OPC manufacturer support OPC UA standard? OPC DA is outdated.
You need a 3rd party OPC server to use the mentioned protocols.
April 26, 2022 at 10:59 pm #10226alex19rc
ParticipantHello Mikhail.
Our OPC provider, they have a solution for OPC UA. I have tried to integrate it but it generates an error in the certificates.
At this point how could we move forward, I am available to do the tests you indicate.
April 27, 2022 at 11:34 am #10227
Please create a new topic in this subforum and provide the error details.
