MikhailModeratorIf you need help while implement such formula, ask.
The general idea is using the channel of the Calculated real type which is calculated every iteration.
In the formula you should check the time difference with the previous calculation.
If the difference >= 1 second, do the required calculations.
MikhailModeratorThank you for the description. Your software is interesting!
A file *.sch should be loaded to get max component ID. However, you should load it anyway to append new components.June 26, 2022 at 8:49 am in reply to: How to set the number after the comma to 2 digits (Elastic Report)? #10385
MikhailModeratorCould you publish a screenshot of the channel 9405 properties?
What output format do you use, HTML, PDF or Excel?-
This reply was modified 4 years ago by
June 24, 2022 at 3:09 pm in reply to: How to set the number after the comma to 2 digits (Elastic Report)? #10381
It uses format of the input channel. Check that it is set.
MikhailModeratorThere is a magic command that I use sometimes to fix SSL issues:
sudo apt-get install --reinstall ca-certificates
MikhailModeratorLet’s close this topic.
OK.
The issue is weird. In version 6 we’ve made uploading configuration more clear, and I expect that such problem will not appear.
MikhailModeratorAlternatively, consider sending notifications by Telegram messenger.
MikhailModerator
Could you explain your question?
May be you should try sending email with simple text.
I suggest to contact Yandex technical support.
Computer code is displayed by a plugin. See the instructions.
MikhailModeratorAll *.sh files should be executable. Not only svc_restart.sh
I suggest to run make_executable.sh
Check the settings:
https://ibb.co/hKd7VfT
MikhailModeratorCould you provide a screenshot of *.sh file attributes?
It would be better to solve it. -
