we are making software which will auto generate interface xml code, based on the image that we feed it. I am wondering about component ID, it looks that is unique. But I changed value of few components to same ID and it looks that it is still working as it should. What happen if you have duplicate ID for components inside Interface?
Duplicated component IDs may cause unexpected behavior of Scheme Editor.
If you generate a scheme by some tool, you should provide unique component IDs.
We have a separate vision program that scans image of GUI from HMI and generates a file where it says that at x-y position is some element.
Then we have a program that would generate interface file with position of all element so that person should just have to enter Input channel.
Both are custom programs build by our company.
Thank you for the description. Your software is interesting!
A file *.sch should be loaded to get max component ID. However, you should load it anyway to append new components.
