Calculated Using Formula once in every Second
Forum Home › Forums › Understanding the Software › Formulas › Calculated Using Formula once in every Second
  • #10384
    CCKOH
    Anyone can advise how to calculated using formula once in every Second (s).
    Rapid SCADA only provide Minute Real & Hourly Real. Can someone advice how to modify for Second Real?
    I’m need for calculation of power consumption, kWh which if base on Minute Real is not accurate for my System Application.
    #10390
    The general idea is using the channel of the Calculated real type which is calculated every iteration.
    In the formula you should check the time difference with the previous calculation.
    If the difference >= 1 second, do the required calculations.
    #10391
    If you need help while implement such formula, ask.
