Viewing 15 posts - 2,011 through 2,025 (of 6,290 total)
  • in reply to: Displaying Websites in a Dashboard #12055
    The above video is not displayed because it was removed from YouTube. You should find active live channel to check.
    Question about streaming video from camera is discussed here.
    in reply to: Telegram Api Bug #12051
    Telegram is a driver that works with Communicator. Webstation version is not important. I recommend to update Rapid SCADA at least to the version 5.8.4.
    in reply to: SMS GSM Cinterion Modem #12050
    Dear Han,
    KpSms.dll of any version supports Huawei e1750
    in reply to: Zoom icons in Chartpro plug-in #12047
    Thank you for the screenshot.
    I’ve added this issue in the list. Will think how to solve it.
    in reply to: Telegram Api Bug #12046
    Copy DrvTelegram.Logic.dll into /opt/scada/ScadaComm/Drv
    Copy DrvTelegram.View.dll into SCADA\ScadaAdmin\Lib on Windows
    Copy driver’s language files into SCADA\ScadaAdmin\Lang on Windows
    in reply to: Double vs Int #12045
    In most cases, the Data Type field of in the Channels table should be blank that is the same as Double.
    in reply to: ArchiveDATCopy #12044
    In the project, open Server – Archives. You should create a new archive for data copy or activate the existing copy archives. By default, data copy uses PostgreSQL archives. If needed you can change the settings.
    in reply to: SMS GSM Cinterion Modem #12035
    The SMS driver has been ported to v6. It is tested with Huawei e1750.
    Successful data communication is in the screenshot https://ibb.co/MkdbhqG
    • This reply was modified 3 years, 4 months ago by Mikhail.
    in reply to: ScadaClient.GetSlice #12034
    May be we should add a method to get values closest to the specified timestamp.
    in reply to: ScadaClient.GetSlice #12033
    To get a slice, you need to specify the exact timestamp. There is a very low chance that data exists exactly at DateTime.UtcNow.AddMinute(-1).
    To be able to get slices, you should write data with a period. And specify the exact timestamps that fits the writing period.
    in reply to: Remote Communicator Error #12032
    does the server need to know the address of the communicator as well?
    No.
    Make sure that you try to upload configuration to the proper instance.
    Also try to connect to the remote Agent by a utility, like telnet using IP and port 10002.
    Check the Agent connection in the instance profile. Port should be 10002.
    in reply to: Zoom icons in Chartpro plug-in #12031
    This is not an image, but a font symbol.
    Could you provide a screenshot?
    in reply to: Double vs Int #12030
    The default data type for channels is double. This data type allows to store either integers or floats. Channel formulas should return double because channels are stored as doubles.
    I recommend, not to use channel data type in the Channels table if you don’t have significant reasons to do that. Channel data type must match a tag data type provided by a device driver, which is double in most cases.
    in reply to: Required to write a formula for a command #12029
    Because the Double data type allow sto use fractional part of a number.
    in reply to: Migrate data from 5.x to 6.X #12028
    1. Could you provide a screenshot?
    2. SNMP driver has been ported to v6 recently and will be included in the next release.
