Viewing 15 posts - 1,651 through 1,665 (of 6,289 total)
  • in reply to: How many bit in DWORD and WORD #12984
    in reply to: Elastic Plugin exports PDF garbled characters #12982
    – Operating system version
    – Elastic Report Plugin version
    in reply to: How to set up Telegram #12981
    Please provide a link to a screenshot of the device settings in Communicator.
    in reply to: Error while receiving data #12974
    The request is different comparing with the previous version. That means that the device settings were changed. Make sure that you configured the device properly. Use https://rapidscada.net/modbus to check requests.
    in reply to: incorect format od data recevied #12973
    Please copy the question to the appropriate topic, or create a new topic. This topic is about incorrect data format error.
    in reply to: Check scada user authentication #12969
    Integration with Grafana is similar. Grafana dashboards have URL with long GUID. Depending on the settings, they can be open separately by a user who knows that URL.
    Rapid SCADA web page can interact with your page by sending HTTP requests. POST requests more hidden from a user comparing with GET requests. For example, your page may require special POST request before providing data.
    in reply to: Check scada user authentication #12966
    User auth information is stored in cookies. Browser protects cookies from access by other websites. So your web service cannot get login information, because it has another origin and another browser session.
    May be it’s possible if you somehow join the Webstation web app and your web service in a one origin (host and port).
    in reply to: Error calling the GetCurDataByView #12965
    Likely, the port 10000 is used by another application.
    in reply to: Error while receiving data #12964
    Could you update Rapid SCADA to 6.1.3?
    Then let us know if the error is fixed by the update or not.
    in reply to: Error while receiving data #12959
    What is the version of Modbus Driver?
    in reply to: Rapid SCADA 6 Beta #12955
    But does it require restart of the scadaserver service to be effective after changing alarm limit settings if configuration stored in DB?
    Currently, yes. We need a special command to reload users and limits to avoid restart.
    Limits are checked many times a second, so we can’t read them from the database every time, and should keep them in the memory cache.
    in reply to: Upgrade from 5.0.3.0 to 5.8.4 #12954
    ModDBExport.dll and ModDbExport.dll use different symbol casing.
    That means, it ist possible to make a screenshot, but i cant´t place it in the trxtfield here.
    Use an external image hosting like https://imgbb.com/ or Google Drive.
    in reply to: Elastic Report Flexibility #12952
    Elastic Report was fixed and uploaded to the website. To use it, you should upgrade Rapid SCADA to 6.1.3.
    in reply to: Upgrade from 5.0.3.0 to 5.8.4 #12949
    ModDBExport.dll was renamed to ModDbExport.dll
    Could you make a screenshot of the Server directories specified in the project?
    in reply to: Rapid SCADA 6 Beta #12947
    You can find in ScadaInstanceConfig.xml the option to change file storage to PostgreSQL storage. If the PostgreSQL storage is selected, the Server app loads a project from the database.
