incorect format od data recevied
Forum Home › Forums › Runtime Bugs › Server Bugs › incorect format od data recevied
  • #12161
    Jure
    I just installed version 6.02 to test it. Installation finished without errors. But when I try to open SCADA in browser I get following errors:
    2023-03-03 10:10:22 [DESKTOP-HE47BH6][DESKTOP-HE47BH6$][ACT] Client 127.0.0.1 disconnected
    2023-03-03 10:10:22 [DESKTOP-HE47BH6][DESKTOP-HE47BH6$][ACT] Session with ID -8554438250878693814 created
    2023-03-03 10:10:22 [DESKTOP-HE47BH6][DESKTOP-HE47BH6$][ACT] Client 127.0.0.1 connected
    2023-03-03 10:10:22 [DESKTOP-HE47BH6][DESKTOP-HE47BH6$][ERR] Incorrect format of data received from client 127.0.0.1: data length is too big
    2023-03-03 10:11:22 [DESKTOP-HE47BH6][DESKTOP-HE47BH6$][ACT] Client 127.0.0.1 disconnected
    2023-03-03 10:11:22 [DESKTOP-HE47BH6][DESKTOP-HE47BH6$][ACT] Session with ID 7728946414698059397 created
    2023-03-03 10:11:22 [DESKTOP-HE47BH6][DESKTOP-HE47BH6$][ACT] Client 127.0.0.1 connected
    2023-03-03 10:11:22 [DESKTOP-HE47BH6][DESKTOP-HE47BH6$][ERR] Incorrect format of data received from client 127.0.0.1: data length is too big
    2023-03-03 10:12:27 [DESKTOP-HE47BH6][DESKTOP-HE47BH6$][ACT] Client 127.0.0.1 disconnected
    2023-03-03 10:12:47 [DESKTOP-HE47BH6][DESKTOP-HE47BH6$][ACT] Session with ID 882446067344896114 created
    2023-03-03 10:12:47 [DESKTOP-HE47BH6][DESKTOP-HE47BH6$][ACT] Client 127.0.0.1 connected
    2023-03-03 10:12:47 [DESKTOP-HE47BH6][DESKTOP-HE47BH6$][ERR] Incorrect format of data received from client 127.0.0.1: data length is too big
    2023-03-03 10:13:16 [DESKTOP-HE47BH6][DESKTOP-HE47BH6$][ACT] Session with ID -8993996409445558107 created
    2023-03-03 10:13:16 [DESKTOP-HE47BH6][DESKTOP-HE47BH6$][ACT] Client 127.0.0.1 connected
    2023-03-03 10:13:16 [DESKTOP-HE47BH6][DESKTOP-HE47BH6$][ERR] Incorrect format of data received from client 127.0.0.1: data length is too big
    I tried different browsers but I get the same error. In WebStationg logs there is nothing. And If I check Instance status, Server and Communicator are normal while WebStation is Not Available.
    #12164
    Do you have the both Rapid SCADA 5 and 6 on the same computer? If so, you should stop the services of the 1st instance before using the 2nd one.
    Which URL do you use to open the Webstation app?
    #12168
    Jure
    No I only have RS 6 installed.
    URL to connect is: http://localhost:10000/
    Port is the same as in Webstation -> Application options
    #12169
    Use http://localhost:10008/
    10000 is a Server port. When you try to connect it from web browser, Server just reports about errors.
    10008 is the default web app port.
    • This reply was modified 3 years, 8 months ago by Mikhail.
    #12171
    Jure
    If I try 10008 I get following error:
    https://imgur.com/a/gMwyDwU
    There is nothing in Webstation logs.
    #12172
    Jure
    Also If I go in to ScadaWeb folder and manually run ScadaWeb.exe it creates http server on port 5000. If I then try to open localhost:5000 it opens the login page.
    #12184
    Check that AspNetCoreModuleV2 is installed as described here.
    #12185
    Jure
    I run repair trough AspNetCoreModuleV2 installation and now it works OK. Thank you for the help.
    #12189
    loukas konstantinou
    i am following this procedure https://rapidscada.net/docs/en/5.8/use-cases/modbus-protocol#customizing-interface and on the Customizing Operator User Interface i cant seem to find where the interface node is in the v6 of Rapid SCADA.
    #12973
    Please copy the question to the appropriate topic, or create a new topic. This topic is about incorrect data format error.
