If you creating a new project, I recommend to use Rapid SCADA 6, which has an auto login feature out of the box.
If you prefer to use Rapid SCADA 5, could you download the above link using VPN?
1) Not yet, we can help you on the forum. The most important is establishing a connection. You already done it.
2) It’s weird.
Root topic can be blank for testing.
This image contains a subscription example https://ibb.co/0X1g0Qs
How do you enter a subscription name?
MikhailModeratorCurrently, Telegram Driver can only send messages, and cannot read incoming messages. Therefore, for now it’s not possible. It will be possible when we implement reading messages by the driver.
MikhailModerator“Current data copy” archive is marked as default in the configuration database. So data should be written to the archive if it is active in the Server settings.
You should check archive status and errors in log files.-
This reply was modified 2 years, 10 months ago by
MikhailModeratorAlso works for me on wine-8.13 (staging).
To check Wine version, usewine --versioncommand.
Could you provide results of performance test in number of records and milliseconds?
For executing custom scripts, may be Database Export Module is better suited.
Standard commands expect numeric command result.
To use byte array, change command type to Binary.
Thank you. This information may be helpful.
MikhailModeratorI recommend to use the latest versions of all apps.
Update is described at https://rapidscada.net/docs/en/latest/installation/install-windows#update
MikhailModeratorLog files would help.
What is the current formula of the output channel?
MikhailModeratorWhat hardware do you use for Rapid SCADA?
For example, ScadaServer can take a long time to run on ARM.
MikhailModeratorDo you really get messages like [ServiceCommandFailed]? If so, we should find how to fix them. What is your Rapid SCADA version?
You should analyze why services are restarted so long. Restart services one by one using svc_restart.bat or svc_restart.sh and check log files.
MikhailModeratorIt is more handy to use the default connection for many different modules.
