SendCommand function
Forum Home › Forums › Communicating with Devices › SendCommand function
  • #12546
    quintelosky
    Hi
    How I can use ‘sendcommand’ in a function?
    I want send multiple commands with a button (I not want to use Automatic Control Module)
    Can someone explain it?
    #12549
    Scripts in the configuration database don’t support sending commands. Automatic Control Module is needed for this purpose.
    #13119
    Keano
    Is it possible to send a command from a button setup on my telegram bot for example, I get a message Alerting me when the generator receives an overvoltage alarm, I would like to click a reset button under my message alerting me that then sends a Modbus signal to reset the generator?
    #13126
    Currently, Telegram Driver can only send messages, and cannot read incoming messages. Therefore, for now it’s not possible. It will be possible when we implement reading messages by the driver.
    #13131
    Keano
    Will this be done using the same as the current telegram driver ? Or not
    #13158
    Update the existing Telegram Driver to read incoming messages is in the wish list. For now, I can’t provide release date.
