I used to use python driver to pull data from RS5 and do batch insertion into PgSQL for data analysis. Recently I tested a little more with the ModArcPostgreSql. With this and ExtDepPostgreSql, if the SQL performance can improve further, I can deprecate my python driver and play data in PgSQL directly once my production setup is upgraded to RS6. 😀
So far, I have only tested Current data archive, the performance doesn’t seem very good (I have triggers setup on this table for testing).
I checked the source, it seem that the update is done in a line by line approach. I would suggest to do this with batch insertion into a temp table and batch update from that table in postgres instead of direct update line by line especially with ON CONFLICT clause. I am sure this would enable the module to work much more performantly even under heavy load.
This approach worked quite well for my python scripts when doing batch updates.
sql_mk_tbl = "CREATE TEMP TABLE temp1 ON COMMIT DROP AS SELECT o, e, t FROM (VALUES "
for cnlnum, vlist in data.items():
if cnlnum in self.fwd_cnls.keys():
ret += f"({int(self.fwd_cnls[cnlnum])}, {int(vlist[0])}, '{ts:%Y-%m-%d %H:%M:%S}'::timestamp),"
ret = ret.rstrip(",") + " ) as x(o,e,t);"
sql = f"""-- BEGIN
-- send data in batch
{sql_mk_tbl}
-- update in batch
UPDATE utsys.obj_state SET p_ev = temp1.e, t = temp1.t from temp1 WHERE temp1.o = obj_state.p_obj;
COMMIT;
-- END"""
This topic was modified 3 years, 2 months ago by
zzz.
