AutoLogin Plugin
Forum Home › Forums › Uncategorized Issues › AutoLogin Plugin
  • #13120
    qqaz
    hi @mikhail I saw the AutoLogin Plugin you mentioned in a post, but I can’t open this link(https://disk.yandex.ru/d/RZArYfy89mgjkw), is it convenient to send the code to my email? Thank you very much
    “The Webstation app stores login info in the HTTP session. I suppose, you need a small plugin written in C# that performs login for you. For example, AutoLogin Plugin.“
    #13129
    If you creating a new project, I recommend to use Rapid SCADA 6, which has an auto login feature out of the box.
    If you prefer to use Rapid SCADA 5, could you download the above link using VPN?
    #13136
    qqaz
    thanks
