Forum Home › Forums › Development and Integration › Can’t get the ModArcPostgreSql to work
- This topic has 5 replies, 2 voices, and was last updated 3 years, 3 months ago by
July 27, 2023 at 2:26 pm #13059
zzz
ParticipantNot sure what host is it referring to ?
2023-07-27 22:19:37 [wsta][appstack][ACT] Start listener on port 10000 2023-07-27 22:19:37 [wsta][appstack][INF] Archive in DAT format: /app/appstack/rapidscada6/Linux/scada/Archive 2023-07-27 22:19:37 [wsta][appstack][INF] Archive copy in DAT format: /app/appstack/rapidscada6/Linux/scada/ArchiveCopy 2023-07-27 22:19:37 [wsta][appstack][ERR] Error calling the MakeReady method of the CurCopy archive: System.ArgumentException: Host can't be null at Npgsql.NpgsqlConnectionStringBuilder.Validate() at Npgsql.NpgsqlConnection.GetPoolAndSettings() at Npgsql.NpgsqlConnection.set_ConnectionString(String value) at Npgsql.NpgsqlConnection..ctor(String connectionString) at Scada.Server.Modules.ModArcPostgreSql.Logic.DbUtils.CreateDbConnection(DbConnectionOptions options) at Scada.Server.Modules.ModArcPostgreSql.Logic.PostgreCAL.MakeReady() at Scada.Server.Engine.ArchiveHolder.MakeReady() 2023-07-27 22:19:37 [wsta][appstack][ACT] Delete outdated data from the Min archive older than 27/07/2022 2023-07-27 22:19:37 [wsta][appstack][ACT] Delete outdated data from the Hour archive older than 27/07/2022 2023-07-27 22:19:37 [wsta][appstack][ACT] Delete outdated data from the Events archive older than 27/07/2022 2023-07-27 22:19:38 [wsta][appstack][ACT] Session with ID -7282601398215451423 created 2023-07-27 22:19:38 [wsta][appstack][ACT] Client 127.0.0.1 connectedThe connection string displayed in module configure window (I didn’t use connection string)
Host=127.0.0.1;Port=5432;Database=wstadb;Username=postgres;Password=[HiddenPassword]-
This topic was modified 3 years, 3 months ago by
zzz.
July 28, 2023 at 7:01 am #13064zzz
ParticipantOK, I got it.
In CurCopy ArchiveProperties>Current Archive OptionsI left theUse default connectionas ticked. And the default connection is actually always an empty connection with all fields set to “”, (at least when checked in PostgreCAL.MakeReady()). UntickUse default connectionfixes the problem.-
This reply was modified 3 years, 3 months ago by
zzz.
July 28, 2023 at 7:46 am #13067
MikhailModeratorScadaInstanceConfig.xml format is changed. Therefore, default connection string became empty.
Actual ScadaInstanceConfig.xml example
<?xml version="1.0" encoding="utf-8"?> <ScadaInstanceConfig> <Culture>en-GB</Culture> <LogDir>R:\SCADA\</LogDir> <ActiveStorage>FileStorage</ActiveStorage> <Connection> <Name>Default Connection</Name> <DBMS>PostgreSQL</DBMS> <Server>localhost</Server> <Database>rapid_scada</Database> <Username>postgres</Username> <Password>4D83D8AEB31C1B40335A78AF3539DD22</Password> <ConnectionString /> </Connection> <Storages> <Storage code="FileStorage"> <ViewAvailable>false</ViewAvailable> </Storage> <Storage code="PostgreSqlStorage"> <ViewAvailable>true</ViewAvailable> <WaitTimeout>30</WaitTimeout> </Storage> </Storages> </ScadaInstanceConfig>July 28, 2023 at 7:47 am #13068
MikhailModeratorIt is more handy to use the default connection for many different modules.
July 28, 2023 at 9:15 am #13072zzz
ParticipantMy setup was messed up I guess, I updated the ScadaServer/Comm/Web/Agent by replacing the folder and overwrite the new Config dir with the old one.
But my ScadaAdmin was still old 6.0.0. could that be the reason ?
There isn’t an immigration guide, or is there ? 😀
zzz.
July 28, 2023 at 2:10 pm #13083
MikhailModeratorI recommend to use the latest versions of all apps.
Update is described at https://rapidscada.net/docs/en/latest/installation/install-windows#update -
