Archives by ModArcPostgreSql curcopy_current no data
Forum Home › Forums › Uncategorized Issues › Archives by ModArcPostgreSql curcopy_current no data
  • #13094
    qqaz
    curcopy_current is configured the same as cur_current. cur_current has data, but curcopy_current(active) has no data. postgresql is used
    #13096
    zzz
    Maybe check your ConfigDB for the Archive bits in Channels.
    Make sure you have set the bits for this copy archive,
    or simply set the bits empty to save to all.
    #13113
    “Current data copy” archive is marked as default in the configuration database. So data should be written to the archive if it is active in the Server settings.
    You should check archive status and errors in log files.
    • This reply was modified 3 years, 2 months ago by Mikhail.
    #13121
    qqaz
    @zzz @mikhail thank you
