Viewing 15 posts - 1,036 through 1,050 (of 6,288 total)
  • in reply to: Issue with Comm Line Termination #14740
    When the Communicator service starts, it starts all lines. If some line is not started, the info is written in ScadaComm.log
    Try restarting the Communicator service and check ScadaComm.log for errors.
    in reply to: ExtDepPostgreSql question #14739
    The schema name is fixed. For another project you should use another database.
    in reply to: Logging Data per second #14738
    Could you provide a screenshot of the latest archive options?
    in reply to: Formula for Communication Line status and Device Status #14737
    It should work in 6.1.x
    Channel data type is empty.
    Channel type is Input
    Tag code is Status
    I didn’t find any place to verify the channel binding status.
    Yes. It’s not displayed in Communicator.
    in reply to: More detailed archive classification #14727
    Currently, this feature is not supported. I hope we will implement it in the future.
    in reply to: Dropdown menu #14725
    If you are asking about adding a menu on a mimic diagram, currently this is not supported. You could add buttons, or display another view in a modal dialog by clicking a button.
    in reply to: Installation Failure IIS 7 #14724
    Check this link.
    in reply to: DB export #14720
    The screenshot is correct. You can set device and object fields to empty. Channel number is enough.
    Press F12 in browser and check if there are any errors in console.
    in reply to: DB export #14714
    Don’t forget to check variables available in a SQL request.
    in reply to: DB export #14713
    If I understand the question correctly, you need to execute a SQL query on a command. First, try sending a command manually by a user. Note that SetData() function does not send a command. To send commands according to conditions, use Automatic Control Module.
    in reply to: TCP/IP Problem #14712
    ByDriver means that a driver parses an incoming request to decide what device the request belongs to. It is usually used in slave mode when we cannot identify device by IP or hello packet.
    in reply to: TCP/IP Problem #14711
    The existing configurations belong to project owners, so can’t be shared. Provide screenshots of your settings to check.
    Note that after connection a modem should send a “hello packet” to identify a device. If it’s not supported by the modem, you need to use different TCP port for each device.
    Configure a Modbus Slave device. Then you will find the code in ScadaComm.log
    in reply to: Logging Data per second #14701
    Archive kind should be Historical.
    The Is Default checkbox should be unset.
