ExtDepPostgreSql question
Forum Home › Forums › Development and Integration › ExtDepPostgreSql question
  • #14728
    zzz
    This is the second time after I first tried RS6 to use this feature.
    – Kodus that nasty C# style casing column name finally gone, no more escaping mess for double quotes. 😀
    – Schema name seems to have changed from rapidscada6 to project (otherwise I used to figure out how to set the projectname ?)
    Question: how to set the schema name of the exported tables to sth other than project?
    #14739
    The schema name is fixed. For another project you should use another database.
