DB export
  • #14704
    quintelosky
    Hi everybody
    I’m doing some test with dbexport module. I can export current data but I don’t know event query works.
    I want execute a dbexport query via script, forcing an event (I have a function that change tag status)
    How can I execute a query dbexport associated only a one tag?
    https://ibb.co/02mb4N3
    When I execute the function, I receive in log file: Unknown exporter command
    Many thanks
    #14713
    If I understand the question correctly, you need to execute a SQL query on a command. First, try sending a command manually by a user. Note that SetData() function does not send a command. To send commands according to conditions, use Automatic Control Module.
    #14714
    Don’t forget to check variables available in a SQL request.
    #14716
    quintelosky
    Hi
    Not exactly.
    I only need: when I press a button, launch a sql for a determinate cnl written values from other channel.
    With that works for me:
    https://ibb.co/4YKJ94J
    I don’t know if exists other method to do the same
    Many thanks
    #14720
    The screenshot is correct. You can set device and object fields to empty. Channel number is enough.
