ScadaWeb Table view on RP4 – only Current data visible
Forum Home › Forums › Rapid SCADA on Linux Controllers and Raspberry Pi › ScadaWeb Table view on RP4 – only Current data visible
  • #14715
    ArunRuchir
    I have a successfully running server on RP4. I have also established MQTT connection and few data points are coming. I am facing 2 issues
    1) While using Table View on WebPage – I am getting only Current Value and all other columns remains empty all the time. I do get Graph if I click on any Tag.
    2) Try schematic view and not getting dynamic values associated with a channel.
    Looks like some minor configuration errors. Pls suggest.
    #14717
    zzz
    Make sure the channels’ archive bits have Minute Archive ticked ?
    I’v never tried schematic view.
    • This reply was modified 2 years, 4 months ago by zzz.
    #14719
    Press F12 in browser and check if there are any errors in console.
    #14722
    ArunRuchir
    Hi ZZZ,
    <Arun> I did this – but no benefit. Only Current values are visible. Rest all columns remains blank.
    Any further suggestion please.
    Dear Mikhail, thanks I rechecked and it was my mistake. Wrong Channel mapped. Now its working fine.
    I am using 6.2.1 version.
    Regards
    Arun
    #14780
    zzz
    I think I got it. The resting hourly columns depends on hourly archive, without an hourly archive, they may remain empty.
    If you have minutes archive enabled, click on the Channel names, the proceeding graph should have the data shown correctly though,
