Forum Home › Forums › Understanding the Software › Logging Data per second
- This topic has 14 replies, 3 voices, and was last updated 2 years, 4 months ago by
June 10, 2024 at 8:59 am #14649
aryabhaskara
ParticipantDear Mikhail,
New user here. I want to log data per second but in historical data report, minute archive is the closest I had.
Please kindly help.
Best regards
AryaJune 10, 2024 at 9:06 am #14651
MikhailModeratorDear Arya,
I suggest to add a new archive in the Archives table and in the Server settings.
This archive should not be default. Set archive mask for channels that will be written in the archive.June 10, 2024 at 9:09 am #14652aryabhaskara
Thanks for the swift reply!
How to do that in detail?
June 11, 2024 at 9:48 am #14657aryabhaskara
I add some setting in Archives and in the Server, also with the masking.
See the link to the picture.
https://drive.google.com/drive/folders/17-9jcaT4eXC7LNCVizG7KRoyqwqAYUMj?usp=drive_link
After I deploy the setting, it is still the same, no logging per second.
Is there any other way?
I also try to pull the data using MySQL but it is not working. Please kindly help.
June 11, 2024 at 10:39 am #14658
Currently access by the above link is denied. Please make it public.June 11, 2024 at 12:23 pm #14659aryabhaskara
Apologies for the inconvenience. You can access the link now.
June 12, 2024 at 12:30 pm #14671
MikhailModeratorStill got “Access denied”.
To check that, open the link in another browser without Google sign in.June 13, 2024 at 10:49 am #14690aryabhaskara
Done. Sorry for the inconvenience
June 14, 2024 at 9:47 am #14701
Archive kind should be Historical.
The Is Default checkbox should be unset.June 21, 2024 at 8:44 am #14735aryabhaskara
Thanks a lot for the advice. I got the archive all set, however the data is not recorded in seconds. Here I attached the XML historical report.
Please kindly assist.
This reply was modified 2 years, 5 months ago by
aryabhaskara.
June 21, 2024 at 9:24 am #14738
Could you provide a screenshot of the latest archive options?June 21, 2024 at 9:29 am #14742aryabhaskara
Please find the link below.Archive Set
June 24, 2024 at 9:30 am #14767
Navigate to Servier – Archives, select the Sec archive, click the Properties button. Then make a screenshot.July 11, 2024 at 1:04 am #14918takslasher
ParticipantThank you for the thread, moved it down the list and it helped (Server-> Archive).
In version 5 reports could be viewed and exported in CSV format! Is it not the option anymore in 6.2.1 version?
When trying to open XML file it says XML file does not appear to have any style information.Regards.
July 11, 2024 at 11:53 am #14921
MikhailModeratorPlease use a proper topic for another question that is not related to logging data per second.
There should be a solution in v6. -
