As there is no video or detailed manual for Auto Report installation I have stuck on testing it on version 6.
Feel free to ask here. I hope we will create videos to cover the most of questions in the future.
Create a device and an output channel to send and receive commands for generating reports.
It’s not needed. AutoReport is a separate service that has it’s own schedule to run reporting tasks.
This reply was modified 1 year, 9 months ago by
MikhailModeratorWere you able to obtain the data using the bit number?
MikhailModeratorData polling seems OK.
I recommend:
1. Use Rapid SCADA 6, because Rapid SCADA 5 is outdated.
2. Provide names for the elements in the Modbus template.
3. Create a simple table view to check data displaying. Then create a scheme view.
MikhailModeratorYes.
MikhailModeratorThe Minute archive has bit 1.
See https://ibb.co/jv7HS8JSeptember 16, 2024 at 7:52 am in reply to: How to retrieve data from the Channels table in a custom module? #15472
MikhailModeratorProbably, you need both.
In the current version of Map Plugin the status colors are predefined.
It can be a good idea to implement more colors in the future versions of the plugin.
MikhailModeratorThe result is the file without any extension and only data in it below
The output filename should have the same name as it was entered.
MikhailModeratorInput and output timestamps in UTC.
Open the Archives table of your project. Please check if there is an archive with bit 11 in the table?
MikhailModeratorSend screenshots of the settings if you need more details.
You need to create a new channel of the Calculated type with a formula
Val(101) > Val(102) ? 1 : 0
Then use the number of the new channel in the module in the trigger. To use the channel value in a command, you need to set output formula of the channels that are used for sending commands:Val(101) / 8
MikhailModerator🙂
MikhailModeratorwill I be able to publish scada data to a standalone mqtt broker, so that other application can subscribe it to get the data ?
can you mention the steps to enable and communicate Mqtt PublisherYes, you can. To get more info about configuring that driver, please create a new topic related to MQTT Publisher.
