Rapid scada data streaming API
Forum Home › Forums › Uncategorized Issues › Rapid scada data streaming API
  • #15414
    rajatdas2005
    I have created a scada project with opcua client as a communication line with associated opcua nodes. It gets data from a standalone OPCUA server. Also through rest api GET (http://192.168.1.2:10008/Api/Main/GetCurData?cnlNums=101) and POST (http://192.168.1.2:10008/Api/Main/SendCommand) call I am able to read/write data both in rapid scada and opcua server.
    Now as my data is changing frequently instead of using GET call, is there data streaming API call available by which my application will read the data as soon as it change ?
    #15427
    Try using DrvMqttPublisher driver which publish data on change by MQTT.
    #15438
    rajatdas2005
    Thank you…So by using DrvMqttPublisher, will I be able to publish scada data to a standalone mqtt broker, so that other application can subscribe it to get the data ?
    can you mention the steps to enable and communicate Mqtt Publisher in rapid scada.
    • This reply was modified 2 years, 1 month ago by rajatdas2005.
    #15445
    rajatdas2005
    please provide the steps so that I can expose the rapid-scada opcua client data via MQTT to the external world.
    #15451
    Yes, you can. To get more info about configuring that driver, please create a new topic related to MQTT Publisher.
    #15460
    rajatdas2005
    For both publish and subscribe different topics over MQTT do I need to use both MqttClient and MqttPublisher driver/device ? or only using MqttClient I can do both publish and subscribe ?
    #15471
    Probably, you need both.
    #15473
    rajatdas2005
    And just for publishing data DrvMqttPublisher only will be sufficient ?
    #15477
    Yes.
    #15479
    rajatdas2005
    Device properties using DrvMqttPublisher
    Create Channels
    Using DrvMqttPublisher, not able to create any channels.
    #15487
    Please create a corresponding topic to discuss DrvMqttPublisher.
