OPC DA no values received
Forum Home › Forums › Communicating with Devices › OPC › OPC DA no values received
Viewing 15 posts - 1 through 15 (of 24 total)
  • #15010
    OPCUser
    Hello everyone,
    i am trying to set up a DA to UA Gateway.
    However i do have problems receiving values from my DA Server.
    I am able to browse the server variables, can add variables to a channel,
    but i dont get any values displayed.
    Rapidscada and the OPC DA Server are running on the same machine.
    In the Line log it says, that the value to be received is “(unspecified)”
    [1] OPC DA Comm
    Status                : Normal
    Communication channel : Undefined
    Shared Data (1)
    OpcClassicLineData = <Object>
    Devices (1)
    [1] OPC DA Client : Normal
    [1] OPC DA Client
    Driver       : DrvOpcClassic 6.0.1.2
    Status       : Normal
    Session time : 23/07/2024 12:16:22
    Command time : Undefined
    Sessions (total / errors) : 2137038 / 0
    Commands (total / errors) : 0 / 0
    Requests (total / errors) : 2137038 / 0
    Current Data
    | # | Code                                   | Name                                   | Value | Channel |
    | *********************************************** dude ************************************************ |
    | 1 | Linie_1.PID_Regulator_Extr1_1.Actual_S | Linie_1.PID_Regulator_Extr1_1.Actual_S |   --- |         |
    Sorry for the editing, i dont know how to post a logfile properly.
    Any help is greatly appreciated, in need of further data please let me know.
    Thank you very much in advance.
    David
    • This topic was modified 2 years, 3 months ago by Mikhail.
    #15013
    Could copy a part of communication line log?
    #15014
    OPCUser
    sure thing, here we go:
    2024-07-16 16:35:27 [OPC-WINCC][OPC-WINCC$][ACT] Communicator 6.2.0.0 started
    2024-07-16 16:35:27 [OPC-WINCC][OPC-WINCC$][ACT] Storage FileStorage 6.2.0.0 loaded from file C:\Program Files\SCADA\ScadaComm\FileStorage.dll
    2024-07-16 16:35:27 [OPC-WINCC][OPC-WINCC$][ACT] Start logic processing
    2024-07-16 16:35:27 [OPC-WINCC][OPC-WINCC$][ACT] Driver DrvDsScadaServer 6.0.1.1 loaded from file C:\Program Files\SCADA\ScadaComm\Drv\DrvDsScadaServer.Logic.dll
    2024-07-16 16:35:27 [OPC-WINCC][OPC-WINCC$][ACT] Driver DrvOpcClassic 6.0.1.2 loaded from file C:\Program Files\SCADA\ScadaComm\Drv\DrvOpcClassic.Logic.dll
    2024-07-16 16:35:27 [OPC-WINCC][OPC-WINCC$][ACT] Data source ScadaServer initialized successfully
    2024-07-16 16:35:27 [OPC-WINCC][OPC-WINCC$][ACT] Data source ScadaServer: Receive the configuration database
    2024-07-16 16:35:31 [OPC-WINCC][OPC-WINCC$][ERR] Data source ScadaServer: Error checking server connection:
    Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. [::ffff:127.0.0.1]:10000
    2024-07-16 16:35:31 [OPC-WINCC][OPC-WINCC$][ERR] Unable to start communication lines because the configuration database is not received
    2024-07-16 16:35:37 [OPC-WINCC][OPC-WINCC$][ACT] Data source ScadaServer: Receive the configuration database
    2024-07-16 16:35:40 [OPC-WINCC][OPC-WINCC$][ACT] Data source ScadaServer: The configuration database has been received successfully
    2024-07-16 16:35:40 [OPC-WINCC][OPC-WINCC$][ACT] Start communication lines
    2024-07-16 16:35:40 [OPC-WINCC][OPC-WINCC$][ACT] Start reading commands from files
    2024-07-16 16:35:42 [OPC-WINCC][OPC-WINCC$][ACT] Data source ScadaServer: Connection state is Logged In
    2024-07-23 13:24:40 [OPC-WINCC][OPC-WINCC$][ACT] Stop communication lines
    2024-07-23 13:24:40 [OPC-WINCC][OPC-WINCC$][ACT] Data source ScadaServer: Connection state is Error
    2024-07-23 13:24:40 [OPC-WINCC][OPC-WINCC$][ERR] Data source ScadaServer: Error receiving telecontrol commands:
    Unable to read data from the transport connection: Eine bestehende Verbindung wurde softwaregesteuert
    durch den Hostcomputer abgebrochen..
    2024-07-23 13:24:40 [OPC-WINCC][OPC-WINCC$][ACT] All communication lines are stopped
    2024-07-23 13:24:44 [OPC-WINCC][OPC-WINCC$][ERR] Data source ScadaServer: Error receiving telecontrol commands:
    2024-07-23 13:24:44 [OPC-WINCC][OPC-WINCC$][ACT] Logic processing is stopped
    2024-07-23 13:24:44 [OPC-WINCC][OPC-WINCC$][ACT] Communicator is stopped
    2024-07-23 13:25:09 [OPC-WINCC][OPC-WINCC$][ACT] Communicator 6.2.0.0 started
    2024-07-23 13:25:09 [OPC-WINCC][OPC-WINCC$][ACT] Storage FileStorage 6.2.0.0 loaded from file C:\Program Files\SCADA\ScadaComm\FileStorage.dll
    2024-07-23 13:25:09 [OPC-WINCC][OPC-WINCC$][ACT] Start logic processing
    2024-07-23 13:25:09 [OPC-WINCC][OPC-WINCC$][ACT] Driver DrvDsScadaServer 6.0.1.1 loaded from file C:\Program Files\SCADA\ScadaComm\Drv\DrvDsScadaServer.Logic.dll
    2024-07-23 13:25:09 [OPC-WINCC][OPC-WINCC$][ACT] Driver DrvOpcClassic 6.0.1.2 loaded from file C:\Program Files\SCADA\ScadaComm\Drv\DrvOpcClassic.Logic.dll
    2024-07-23 13:25:09 [OPC-WINCC][OPC-WINCC$][ACT] Data source ScadaServer initialized successfully
    2024-07-23 13:25:09 [OPC-WINCC][OPC-WINCC$][ACT] Data source ScadaServer: Receive the configuration database
    2024-07-23 13:25:14 [OPC-WINCC][OPC-WINCC$][ERR] Data source ScadaServer: Error checking server connection:
    2024-07-23 13:25:14 [OPC-WINCC][OPC-WINCC$][ERR] Unable to start communication lines because the configuration database is not received
    2024-07-23 13:25:20 [OPC-WINCC][OPC-WINCC$][ACT] Data source ScadaServer: Receive the configuration database
    2024-07-23 13:25:23 [OPC-WINCC][OPC-WINCC$][ACT] Data source ScadaServer: The configuration database has been received successfully
    2024-07-23 13:25:23 [OPC-WINCC][OPC-WINCC$][ACT] Start communication lines
    2024-07-23 13:25:23 [OPC-WINCC][OPC-WINCC$][ACT] Start reading commands from files
    2024-07-23 13:25:25 [OPC-WINCC][OPC-WINCC$][ACT] Data source ScadaServer: Connection state is Logged In
    #15021
    The above is ScadaComm.log
    But we need lineXXX.log
    #15022
    OPCUser
    Sorry, my bad. Once again:
    2024-07-24 11:09:41 Device [1] OPC DA Client. Process new data. Subscription: dude
    Receive Linie_1.PID_Regulator_Extr1_1.Actual_S = (unspecified)
    2024-07-24 11:09:42 Device [1] OPC DA Client. Process new data. Subscription: dude
    2024-07-24 11:09:43 Device [1] OPC DA Client. Process new data. Subscription: dude
    #15023
    Can you compare the received data (unspecified) with data collected by any other OPC client? For example, Prosys OPC UA Browser.
    #15024
    OPCUser
    Sure. This is what i can gather with the IntegrationObjets DA Client:
    <SETTING>
    <SOFTWARENAME>OPC Data Access Explorer::Item Properties</SOFTWARENAME>
    <TagInfo>
    <AccessPath/>
    <AccessRight>rw</AccessRight>
    <DataType>VT_I4 </DataType>
    <GroupName>Group_1</GroupName>
    <ItemID>Linie_1.PID_Regulator_Extr1_1.Actual_S</ItemID>
    <ServerAddress>OPC-WINCC</ServerAddress>
    <ServerName>Sigmatek.OPCServer.1</ServerName>
    <State>Active</State>
    <Propertie0>
    <PropertieDescription>Item Canonical DataType</PropertieDescription>
    <PropertieType>VT_I2</PropertieType>
    <PropertieValue>3</PropertieValue>
    </Propertie0>
    <Propertie1>
    <PropertieDescription>Item Value</PropertieDescription>
    <PropertieType>VT_I4 </PropertieType>
    <PropertieValue>749</PropertieValue>
    </Propertie1>
    <Propertie2>
    <PropertieDescription>Item Quality</PropertieDescription>
    <PropertieValue>192</PropertieValue>
    </Propertie2>
    <Propertie3>
    <PropertieDescription>Item Timestamp</PropertieDescription>
    <PropertieType>VT_DATE</PropertieType>
    <PropertieValue>25.07.2024 15:28:36</PropertieValue>
    </Propertie3>
    <Propertie4>
    <PropertieDescription>Item Access Rights</PropertieDescription>
    </Propertie4>
    <Propertie5>
    <PropertieDescription>Server Scan Rate</PropertieDescription>
    <PropertieType>VT_R4</PropertieType>
    <PropertieValue>10.000000 </PropertieValue>
    </Propertie5>
    <Propertie6>
    <PropertieDescription>Item Description</PropertieDescription>
    <PropertieType>VT_BSTR</PropertieType>
    <PropertieValue> </PropertieValue>
    </Propertie6>
    </TagInfo>
    </SETTING>
    #15032
    Communicator works as a service with the system account, while most of OPC clients work as an application.
    Try the following:
    1. Stop the ScadaComm6 service.
    2. Open command line and execute ScadaCommWkr.exe
    What will you get in ScadaComm.log and communication line log?
    #15068
    OPCUser
    Hi Mikhail,
    stopping the service and starting the worker did the trick
    and i do receive values now.
    Here is the ScadaComm.log:
    2024-07-29 13:30:50 [OPC-WINCC][OPC-WINCC$][ACT] Communicator 6.2.0.0 started
    2024-07-29 13:30:50 [OPC-WINCC][OPC-WINCC$][ACT] Storage FileStorage 6.2.0.0 loaded from file C:\Program Files\SCADA\ScadaComm\FileStorage.dll
    2024-07-29 13:30:50 [OPC-WINCC][OPC-WINCC$][ACT] Start logic processing
    2024-07-29 13:30:50 [OPC-WINCC][OPC-WINCC$][ACT] Driver DrvDsOpcUaServer 6.0.0.2 loaded from file C:\Program Files\SCADA\ScadaComm\Drv\DrvDsOpcUaServer.Logic.dll
    2024-07-29 13:30:50 [OPC-WINCC][OPC-WINCC$][ACT] Driver DrvDsScadaServer 6.0.1.1 loaded from file C:\Program Files\SCADA\ScadaComm\Drv\DrvDsScadaServer.Logic.dll
    2024-07-29 13:30:50 [OPC-WINCC][OPC-WINCC$][ACT] Driver DrvOpcClassic 6.0.1.2 loaded from file C:\Program Files\SCADA\ScadaComm\Drv\DrvOpcClassic.Logic.dll
    2024-07-29 13:30:50 [OPC-WINCC][OPC-WINCC$][ACT] Data source ScadaServer initialized successfully
    2024-07-29 13:30:50 [OPC-WINCC][OPC-WINCC$][ACT] Data source OpcUaServer initialized successfully
    2024-07-29 13:30:51 [OPC-WINCC][OPC-WINCC$][ACT] Data source ScadaServer: Receive the configuration database
    2024-07-29 13:30:53 [OPC-WINCC][OPCSrv][ACT] Data source ScadaServer: Connection state is Logged In
    2024-07-29 13:30:54 [OPC-WINCC][OPC-WINCC$][ACT] Data source ScadaServer: The configuration database has been received successfully
    2024-07-29 13:30:54 [OPC-WINCC][OPC-WINCC$][ACT] Start communication lines
    2024-07-29 13:30:54 [OPC-WINCC][OPC-WINCC$][ERR] Error calling the Start method of the OpcUaServer data source:
    System.AggregateException: One or more errors occurred. (Failed to establish tcp listener sockets for Ipv4 and IPv6.)
    —> Opc.Ua.ServiceResultException: Failed to establish tcp listener sockets for Ipv4 and IPv6.
    at Opc.Ua.Bindings.TcpTransportListener.Start()
    at Opc.Ua.Bindings.TcpTransportListener.Open(Uri baseAddress, TransportListenerSettings settings, ITransportListenerCallback callback)
    at Opc.Ua.ServerBase.CreateServiceHostEndpoint(Uri endpointUri, EndpointDescriptionCollection endpoints, EndpointConfiguration endpointConfiguration, ITransportListener listener, ICertificateValidator certificateValidator)
    at Opc.Ua.Bindings.TcpServiceHost.CreateServiceHost(ServerBase serverBase, IDictionary2 hosts, ApplicationConfiguration configuration, IList1 baseAddresses, ApplicationDescription serverDescription, List`1 securityPolicies, X509Certificate2 instanceCertificate, X509Certificate2Collection instanceCertificateChain)
    at Opc.Ua.Server.StandardServer.InitializeServiceHosts(ApplicationConfiguration configuration, TransportListenerBindings bindingFactory, ApplicationDescription& serverDescription, EndpointDescriptionCollection& endpoints)
    at Opc.Ua.ServerBase.Start(ApplicationConfiguration configuration)
    at Opc.Ua.Configuration.ApplicationInstance.Start(ServerBase server)
    at Scada.Comm.Drivers.DrvDsOpcUaServer.Logic.OpcUaServerDSL.StartOpcServer()
    at System.Threading.Tasks.Task.ThrowIfExceptional(Boolean includeTaskCanceledExceptions)
    at System.Threading.Tasks.Task.Wait(Int32 millisecondsTimeout, CancellationToken cancellationToken)
    at System.Threading.Tasks.Task.Wait()
    at Scada.Comm.Drivers.DrvDsOpcUaServer.Logic.OpcUaServerDSL.Start()
    at Scada.Comm.Engine.DataSourceHolder.Start()
    2024-07-29 13:30:54 [OPC-WINCC][OPC-WINCC$][ACT] Start reading commands from files
    2024-07-29 13:30:56 [OPC-WINCC][OPC-WINCC$][ACT] Data source ScadaServer: Connection state is Logged In
    2024-07-29 13:31:15 [OPC-WINCC][OPCSrv][ACT] Application command App.Comm.RestartLine with ID 7397018915087741326 from C:\Program Files\SCADA\ScadaComm\Cmd\cmd_7397018915087741326.dat
    2024-07-29 13:31:15 [OPC-WINCC][OPCSrv][ACT] Stop communication line [1] DA Line
    2024-07-29 13:31:16 [OPC-WINCC][OPCSrv][ACT] Communication line [1] DA Line is stopped
    2024-07-29 13:31:16 [OPC-WINCC][OPCSrv][ACT] Start communication line [1] DA Line
    2024-07-29 13:31:16 [OPC-WINCC][OPCSrv][ACT] Data source ScadaServer: Receive the configuration database
    2024-07-29 13:31:18 [OPC-WINCC][OPCSrv][ACT] Data source ScadaServer: The configuration database has been received successfully
    Here is the communication line log:
    2024-07-29 13:46:00 Device [1] DA Device. Process new data. Subscription: Grp1
    Receive Linie_1.PID_Regulator_Extr1_1.Actual_S = 701 (good)
    2024-07-29 13:46:01 Device [1] DA Device. Process new data. Subscription: Grp1
    Receive Linie_1.PID_Regulator_Extr1_1.Actual_S = 700 (good)
    2024-07-29 13:46:02 Device [1] DA Device. Process new data. Subscription: Grp1
    Receive Linie_1.PID_Regulator_Extr1_2.Actual_S = 1300 (good)
    2024-07-29 13:46:04 Device [1] DA Device. Process new data. Subscription: Grp1
    Receive Linie_1.PID_Regulator_Extr1_2.Actual_S = 1302 (good)
    2024-07-29 13:46:07 Device [1] DA Device. Process new data. Subscription: Grp1
    Receive Linie_1.PID_Regulator_Extr1_2.Actual_S = 1304 (good)
    This seems to be working.
    The OPC UA server is having troubles though. As you can see there are some problems regarding opening listener sockets.
    I am able to connect to to UA Server with UA Expert but i dont have access to
    the variables. I can browse the tree up to the device folder but thats it.
    Thank you very much for your help so far.
    Greetings.
    #15069
    Looks like the ScadaComm6 service is not stopped. Users OPC-WINCC$ and OPCSrv are mixed in the log file.
    #15076
    OPCUser
    That was the problem, indeed. Its working now, thanks a million times.
    Is there a way to restart the OPC UA server after adding new variables
    to the subscription group? I always have to reboot the entire pc
    to make it work.
    #15081
    You should try the setup the ScadaComm6 service to work as the OPCSrv user. See this.
    It’s enough to restart Communicator that works as a service or application.
    #15085
    OPCUser
    Once again, also that worked perfectly. You are really really great.
    Thank you again, thanks for your work and constant and quick help and
    response. Is there any way one can support you?
    #15086
    Purchase of any additional modules is appreciated.
    #15380
    leibiao
    Sorry to interrupt, but please forgive me for interrupting. I’m new to using rapidscada and now I’m having a similar issue, I’m able to explore server variables, I am able to browse the server variables, can add variables to a channel,but i dont get any values displayed.
    This is the content of the device page,there is no value:
    [1] nodered
    Status       : Undefined
    Session time : Undefined
    Sessions (total / errors) : 0 / 0
    Requests (total / errors) : 0 / 0
    Current Data
    | ************************************************* test ************************************************** |
    | 1 | Device1.MoldInfoString.Data              | Device1.MoldInfoString.Data              |   --- |         |
    | 2 | Device1.Parameter_Online.Back_Pressure   | Device1.Parameter_Online.Back_Pressure   |   --- |         |
    | 3 | Device1.Parameter_Online.Back_pressure_1 | Device1.Parameter_Online.Back_pressure_1 |   --- |         |
    2024-09-11 14:19:51 [LAPTOP-QATS2QI7][LAPTOP-QATS2QI7$][ACT] Communicator 6.2.0.1 started
    2024-09-11 14:19:51 [LAPTOP-QATS2QI7][LAPTOP-QATS2QI7$][ACT] Storage FileStorage 6.2.0.0 loaded from file C:\Apply\rapidscada\rapidscada_6.3.0\RapidScadaInstall\ScadaComm\FileStorage.dll
    2024-09-11 14:19:51 [LAPTOP-QATS2QI7][LAPTOP-QATS2QI7$][ACT] Start logic processing
    2024-09-11 14:19:51 [LAPTOP-QATS2QI7][LAPTOP-QATS2QI7$][ACT] Driver DrvDsOpcUaServer 6.1.0.0 loaded from file C:\Apply\rapidscada\rapidscada_6.3.0\RapidScadaInstall\ScadaComm\Drv\DrvDsOpcUaServer.Logic.dll
    2024-09-11 14:19:51 [LAPTOP-QATS2QI7][LAPTOP-QATS2QI7$][ACT] Driver DrvDsScadaServer 6.0.1.1 loaded from file C:\Apply\rapidscada\rapidscada_6.3.0\RapidScadaInstall\ScadaComm\Drv\DrvDsScadaServer.Logic.dll
    2024-09-11 14:19:51 [LAPTOP-QATS2QI7][LAPTOP-QATS2QI7$][ACT] Driver DrvOpcClassic 6.0.1.2 loaded from file C:\Apply\rapidscada\rapidscada_6.3.0\RapidScadaInstall\ScadaComm\Drv\DrvOpcClassic.Logic.dll
    2024-09-11 14:19:51 [LAPTOP-QATS2QI7][LAPTOP-QATS2QI7$][ACT] Data source ScadaServer initialized successfully
    2024-09-11 14:19:51 [LAPTOP-QATS2QI7][LAPTOP-QATS2QI7$][ACT] Data source OpcUaServer initialized successfully
    2024-09-11 14:19:51 [LAPTOP-QATS2QI7][LAPTOP-QATS2QI7$][ACT] Data source ScadaServer: Receive the configuration database
    2024-09-11 14:19:54 [LAPTOP-QATS2QI7][LAPTOP-QATS2QI7$][ACT] Data source ScadaServer: The configuration database has been received successfully
    2024-09-11 14:19:54 [LAPTOP-QATS2QI7][LAPTOP-QATS2QI7$][ACT] Start communication lines
    2024-09-11 14:19:55 [LAPTOP-QATS2QI7][LAPTOP-QATS2QI7$][ACT] Start reading commands from files
    2024-09-11 14:19:56 [LAPTOP-QATS2QI7][LAPTOP-QATS2QI7$][ACT] Data source ScadaServer: Connection state is Logged In
    Here is the Line.log:
    2024-09-11 14:19:54 Start communication line [1] opcda
    2024-09-11 14:19:54 Connect to Sigmatek.OPCServer/{585ac720-c50c-11d3-9b53-00902771f2c1}
    Connection to the OPC DA server has been established
    2024-09-11 14:19:56 Create subscriptions
    Create subscription "test" for the device [1] nodered (async)
    Any help is greatly appreciated, thank you very much in advance.
    • This reply was modified 2 years, 1 month ago by Mikhail.
