Compare values and send modbus value
Forum Home › Forums › Understanding the Software › Formulas › Compare values and send modbus value
  • #15453
    Mohbarah
    Hello I want to do the following can you please give me instruction and if automatic control plugin can achieve this.
    what i will do i will compare 2 values and do a calculation to make it easier what i will do is the following
    val101 > val102 then
    newvalue = val101/8
    then send newvalue to 8 holding registers.
    #15462
    You need to create a new channel of the Calculated type with a formula
    Val(101) > Val(102) ? 1 : 0
    Then use the number of the new channel in the module in the trigger. To use the channel value in a command, you need to set output formula of the channels that are used for sending commands: Val(101) / 8
    • This reply was modified 2 years ago by Mikhail.
    #15464
    Send screenshots of the settings if you need more details.
