Viewing 15 posts - 3,511 through 3,525 (of 6,218 total)
  • in reply to: ModAutoControl executing a binary file on event ? #7354
    Starting scripts feature requires development of a module for SCADA-Server.
    in reply to: How to use Notification plugin? #7353
    Adding custom text to events requires additional development. It’s better to implement this feature in Rapid SCADA 6 in the next year. However, we can do it earlier in the version 5 according to a contract.
    in reply to: Scheme Editor Error opening browser in Ubuntu 20 #7352
    Check the editor settings that a default browser is selected.
    I recommend editing Rapid SCADA projects on Windows then upload them to Linux.
    In the future, Microsoft doesn’t plan provide .NET Forms on Linux Desktop, so the full editors will be on Windows, and may be we will provide a simple web editor.
    This means that likely it’s possible to make the driver work with different security levels. Because the driver uses the same OPC UA libraries. Debug needed.
    I can connect to Node OPCUA server now without modified source code.
    Good.
    I can connect with every 7 combination supported by Node OPCUA from UaExpert dan Prosys including “None and None” but only “Sign & encrypt and Basic256Sha256” with KpOpcUa.
    Interesting. Could you also try this official utility made by OPC Foundation? The source code of the utility is available on OPC Foundation’s GitHub if needed.
    in reply to: How to use Notification plugin? #7343
    The notifications are based on the events in the archive.
    Probably, you should untick the “Event on Change” property of the input channel.
    in reply to: How to set up Telegram #7337
    Write to the bot:
    /info
    If it doesn’t answer, check the communication line log in Communicator.
    in reply to: How to use Notification plugin? #7336
    The manual.
    <Statuses>612</Statuses> – you should put statuses there, not channel numbers. Look for the existing statuses in the Event types table.
    <ParamIDs>11</ParamIDs> – may be it’s better to set empty string inside.
    I’ve copied my answer from GitHub:
    Thank you for the pull request, but I can’t merge it because of the following:
    1. Pull requests in this repository should be targeted to the develop branch.
    2. Removing the lines makes impossible to apply the corresponding configuration options.
    3. You should try changing the device configuration in KpOpcUa_XXX.xml to use the correct SecurityMode and SecurityPolicy.
    Please try the 3rd item and let me know about the result.
    in reply to: communication error #7334
    Please make a screenshot of the Input channels table where we can see the mentioned channels.
    in reply to: Chart/ChartPro Extra Feature #7327
    This is a good idea. I also thought about this feature. Hope, we will find a sponsor to implement it.
    in reply to: Communication with kepware OPC on window 10 #7326
    I’ll open a new thread about this problem later.
    OK.
    in reply to: Modbus RTU comunication issue #7325
    Using Moxa NPort, I prefer TCP server or TCP client mode.
    in reply to: Generating Demo Data for Simulation #7320
    If I were you, I would take the source code of KPSimulator and change it to generate values as needed. The HelloWorld project demonstrates how to use this driver.
    As I know, free Matrikon OPC Simulation Server also generates different values.
    in reply to: MQTT at Linux/Ubuntu #7319
    Thanks for noticing. In Linux file names are case sensitive.
